Not new to the hobby but just recently started again. When it came to mixing paint that has set for awhile, I went to the Dollar store and bought a couple packages of pick up sticks to mix my paint with. They are long enough to get to the bottom of the jar and not get paint on your fingers. You can also use the same stick again and again. I bought also the small sticky strips similar to the stick notes but smaller and marked each stick with the color I used it in. Works great!!
I pick up a handful of the plastic coffee stirrer sticks at McDonald’s whenever I can stand to go there. Use 'em once and throw 'em away, and the price is right!
I like the thin wooden ones from certain coffee shops. If and when I see them I grab a couple. They scrape the bottom of the bottle and mix the paint very well.
I buy the coffee stirring sticks at the grocery store. They are about a buck for a hundred. I don’t drink enough coffee at fast foods to keep enough in stock, though I do add those to my stock. But I go through them fast enough I want to have a good supply in hand. I prefer the hollow tube ones, which can pick up a little paint for mixing a bit of one color with another, with the old “finger over the top” trick. Also use that trick for applying decal setting solution using those stirring sticks.
The sticks I am talking about are hollow tubes about 3/32 inch in diameter and about four or five inches long.
Badger makes a battery powered paint mixer, which I have and use regularly, which is absolutely great for mixing paint that has sat for a while on the shelf. Mixes the stuff up thoroughly and I’ve found that once I use the Badger mixer on a bottle or tin of paint, unless I let is sit for weeks between uses, all I have to do is give it a good shake since the Badger has already thoroughly mixed it up.
Hope this helps. The thing really is worth the money and can be had at Micro-Mark.
I have a badger paint mixer too. If I’m stirring paint after it’s been sitting, I use the mixer. If I’m just re-mixing during a session, I use a toothpick.
After years of stirring, I now also use the (micro mark) paint mixer exclusively. It mixes paint much more thoroughly than stirring with sticks— and in a tenth the time. It also saves paint— after mixing I can lift the head of the mixer just above the surface of the paint in the jar, turn it on for a second, and have almost all the paint from the mixer returned to the bottle by centrifugal force. I’m pretty sure I’ve saved the $10 cost of the mixer in paint alone— not to mention all the time I don’t waste anymore stirring.
I really like the Tamiya paint stirrer. One of my favorite modelling tools. Also great for spooning small amounts of paint into the airbrush and the small end fits well in the paint cup to stir the paint/thinner mixture.
