Ok, asking again for colour referances for the Mig 29.
Any brand will suffice, I just need a basic starting block, after that I can cross referance and mix my own etc.
Any help would be appreciated.
Thanks in advance
Sean
Thanks in advance
Sean
color coats for the Revell MIG 29 UB :
grey color : 80% light grey ( revell 371 ) + 20% grey ( revell 374 )
greygreen color : 60% rush green ( revell 362 ) + 40 % grey ( revell 374 )
the dark grey nose cone is on the color : basalt grey ( revell 77 )
hope it helps you a little.
Testor’s Model Master has both MiG-29 colors in its line listed as " Fulcrum Gray" and “Fulcrum Gray-Green”. These colors are close to FS36440 and FS34233. I’ve used both and they look great cut with about 15% white. For the dark gray you can use Humbrol 27 which is close to FS36152. Hope this helps you.
