Basic kit evaluation:
It seems from my initial observation that everything is very well laid out for a true novice builder. Actually, I shouldn’t put a catagory on this vessle. In the case with this Lobsterboat, it is not at all about a builders abilities, but just having fun building a nice boat that can either be static displayed or having an R/C motor installed. By the way, I will go ahead and mention that the MEPS-III motor from Midwest already has the speed control attached and prewired to it. You will have to have a servo (standard it seems) attached to the speed control. I was thinking that a nice speed control that has a smooth variable spped would be nice, however, this is not what you get with the MEPS-III. It seems rather clunky from the fact that you have two speeds in both forward and reverse. This will do for now as I am not up to researching and buying more electronics for this unit. Maybe in the future.
The wooden parts come in 5 packaged bags which I like, instead of having all the parts thrown into a box. This is a nice departure of what I have seen before. Then you have an accessory bag and a hardware bag - of which again keeps all the parts separated until needed.
Right off, I must say that in bag #3, was some what they refer to as “sub decking” planks that had a slight bow or warp to them. This is really no problem. I just used a non scientific approach and ran some very warm water over the boards just enough to get them wet. I did not soak the boards. I just barely put just enough warm water on them to coat the face and back of boards. Then I laid them on a flat surface with a flat heavy weight on it - like a thick book will do -until dry. I noticed that even after about 5 minutes, the boards were already showing signs of straightening ! Don’t let a bowed or warped board get you down or upset, usually this is very fixable.
The manual is the best manual I have seen (so far) in my wooden kit building experiences. But that is not saying much at all, because, I only have one completed wooden ship under my belt. The manual is 95 pages long - not that it is so much a difficult build that Midwest needs 95 pages, but the pages are filled with pictorials and many steps that to some, might be unnecessary, but I like it - I need all the help I can get!
One other thing about the Manual is that the kit came with a supplement that had corrections sheet in it. The instructions are to cut out each correction and place it in the corresponding section. I did this with no problem, and I suggest that this is done first before you do anything, because there are some situations that will cause you some grief if you do not go ahead and make those changes in the manual - beucase, if you are like me, you will forget!
Well, its about time to check those sub deck planks to see how they are coming along. I can’t think of anything else.
I would mention that if anyone wants to offer a suggestion - I do have a question that I do not have any experience with and that is using the “Slow drying Epoxy” or"Polyester Resin" used to bond figerglass to the hull and water proof the interiorof the Hull. Never done this before!
Thanks for any input,
Donnie
