Metal tubing for MG's
IYO…what is the best source for aluminum or brass tubing for A/C machine guns?
Also…what diameters do you recommend for 1/48 scale .30 and .50 MG’s?
TIA!
Lt, somewhere in the tomb of forums is a chart someone with all the cross reference for Syringe needles. I printed it off but somewhere I misplaced during the remodel of the workshop. [sigh] But I bought several needles that I knew where to find and for 1/48 .50 cal use 26 or 27 gauge needles. I picked mine up at feed store .
Thanks Sean! I’ll check that out!
Gosh Nam most of the Hobby shops got that tubing here on display by the balsa wood for some reason.
here i saved in my favs.
- Sign up for our e-newsletter
- Subscriber-only content
- Downloadable articles
- Customer Service
- Events
| LOGIN | REGISTER |
We have made some big changes at FineScale.com. Learn More. [![|468x60](http://ads.kalmbach.com/creatives/fsm02/megabanner_2.gif)](http://abn.kalmbach.com/scripts/fsm02/adclick.php?bannerid=245&zoneid=66&source=&dest=http%3A%2F%2Fwww.Megahobby.com) *FineScale.com* forums are FREE. If you wish to participate you must LOGIN | [REGISTER](https://secure.kalmbach.com/customer/SignUp.aspx?siteid=7&pubcode=fsm).
Welcome to FineScale.com Forums
Faq | Login | Register
FineScale.com Forums » Tools, Techniques, and Reference Materials » Techniques
Techniques
Started by garthbender at 06-15-2004 7:32 AM. Topic has 4 replies.
Sort Posts: Oldest to newest Newest to oldest
06-15-2004, 7:32 AM
garthbender
Joined on 05-21-2004
Posts 127
Hypodermic Tubing Sizes
I’ve never used hypodermic tubing for gun barrels, but have seen people reference it so much that I’d like to give it a shot. What size should I order for a .50 cal. barrel in 1/48? How about the same .50 cal. in 1/35?
Does anybody have good tips about working with the stuff? Is it hard to cut without collapsing the tube? How do you replicate the holes in the cooling sleeve?
~ Thanks
~ Garth
Report Abuse
06-15-2004, 7:47 PM
MikeV
Joined on 04-19-2003
Hayward, CA
Posts 7,848
RE: Hypodermic Tubing Sizes
Since .50 cal is .5" divide .5 by 48 for 1/48th scale which comes to an inside diameter of .010" which would be 22 gauge hypodermic tubing.
I think the heavy-walled stuff from SmallParts.com would be best as it has a thicker wall and looks more realistic. http://www.smallparts.com/components/
For 1/35 scale it would be .5" divided by 35 which comes to an inside diameter of .014" which would be closest to 21 gauge hypodermic tubing.
This stuff is fairly hard as it is stainless steel,but it cuts great with a Dremel tool with an emery cutting wheel on it. Wear your safety glasses though!
There is no way to drill the air cooling vents in the tubing though.
If you want that kind of realism then you need to buy some of the aftermarket machine guns that they sell.
Report Abuse
06-16-2004, 10:37 PM
garthbender
Posts 127
Awesome! Thanks Mike. I’m going to give this a shot on my next project. I hate when guns have that plastic look, so hopefully this will help.
~ Garth
Report Abuse
06-17-2004, 8:59 AM
jridge
Joined on 04-16-2003
West Des Moines, IA USA
Posts 355
Try this site if you are interested in barrels with the cooling jackets.
http://www.karaya.ceti.pl/eng/eng2.html
I’ve used their 1/48 scale barrels and highly recommend them. I’d pass on thier resin bodies however, unless they’ve drastically improved their molds. I use the kit gun bodies.
Jim
The fate of the Chambermaid
http://30thbg.1hwy.com/38thBS.html
Report Abuse
06-24-2004, 8:20 AM
TimL
Joined on 01-07-2004
Posts 76
50 caliber
Caliber/Scale
.50/72=.0069 29 or 30 gauge
.50/48=.0104 26 or 27 gauge
.50/32=.0156 24 or 25 gauge
.50/24=.0208 21 or 22 gauge
.50/18=.0277 19 gauge
So as not to forget the metric guns, 20mm
The list I have has all the sizes in inches, you can either convert the size now or after you do the scale conversion, I’ll do it now to keep it easy
20mm / 25.4mm per inch = .787 inches
Caliber/Scale
.787/72=.0109 26 or 27 gauge
.787/48=.0164 24 or 25 gauge
.787/32=.0246 20 gauge
.787/24=.0328 19 gauge
.787/18=.0437 17 or 18 gauge
The math is the same and very easy, just divide the nominal bore diameter (.50, .30, 20mm, 30mm) by the scale (72,48,32) and you’ve got it.
There was also a question regarding the calculations being for the bore diameter, in the past when this question came up, most of the time, the person was wondering what the proper inside diameter (ID) of the tube was, you could calculate based on outside diameter (OD) of the gun, but since I don’t have a chart of the OD’s of various guns, I find it easier to calculate by nominal ID.
For example, assuming a 50 caliber gun has a 1/4" wall thickness in real life, this would make the OD of the gun approx. 1" in real life.
And as an example, we’ll use 1/48th scale
1/48= .0208 OD Which is a 25 gauge tube, and does jive with the calculations above.
If the wall diameter in real life is 3/8", then .5+.375+.375=1.25
1.25/48=.026 OD, a 23 gauge tube with an ID of .013, which is close
Report Abuse
Forum Jump:
(please select) Forums Home |- Search Forums |- Active Topics |- Unanswered Posts User Options |- Login |- Register |- Forgot Password Announcements |- Announcements from FineScale Modeler Modeling Subjects |- Aircraft |- Armor |- Autos |- Dioramas |- Figures and Misc. |- Helicopters |- Sci-Fi |- Ships |- Space |- Group Builds |- Scratchbuilding Tools, Techniques, and Reference Materials |- Tools |- Techniques |- Painting and airbrushing |- Decaling |- Reference Materials General Discussion |- Welcome - Introduce Yourself |- General Modeling Discussion |- Odds & Ends |- IPMS Nationals |-- 2005 IPMS Nationals |- Charity and Goodwill Feedback, Help and Testing |- Suggestions and Feedback |-- Forum Feedback & Error Reporting |- Community Assistance (aka Forum Help) |- Testing Forums
Home | Subscribe | Classifieds | Contact Us | Advertising info | Link to us | Carry Us in Your Store | Employment | Press Room
MEMBER EXCLUSIVE: AVAILABLE TO ONLINE PREMIUM MEMBERS Privacy Statement
Copyright © 2008 Kalmbach Publishing Co.
That’s very helpful! Thankyou! Love odd ball! he is my hero!
I appreciate the help, but I NEVER get to a LHS! So lazy and used to just ordering online. I know I need to change my ways!
Also, I needed suggestions about recommended sizes.
But I thank you all!
Nam, here’s the link to my chart in the FSM forums:
scale tubing
Thanks Everyone! I actually went to an LHS Friday afternoon…advertised open until 6 pm.
We got there at 5:30…locked and closed! Ugggggghhhhhhhhhhh!
I use the needle aplicator tubes from “Black bottle” Testor’s Liquid Cement for .50 cal/12.7-13mm guns… .30 cals come from my wife’s used 26’s for her insulin… 20mm gets the 1/16th OD aluminum tubes, everything else gets drilled… Also, wire insulation works as well. I just strip a bit and pull it forward, but leave the wire in to maintain rigidity.
Great tip, Mike
Hello nam,
Here is a chart on sizes of tubing recommended for each scale per type of machine gun and the smallparts.com part number if needed.
The original chart came from Randie Coulter but I added in the missing scales.
http://www.mechanicalrenaissance.com/albums/info/Scale_Gun_Barrel_Chart.pdf
hth
Cheers,
Thom
Thanks Thom! It’s a new ref for me!
What river are you east of?
Nam,
You might also try Minimeca’s products. I picked up their “grab bag” at Squadron last month and it has several tubing sizes that would be ideal. It’s kinda pricey (fifteen bucks and change), but I got enough tubing to do several 1/72 and 1/48 aircraft. There’s also some fine wire, perfect for antennae or aerials. The tubing diameters are .6mm and .8mm in lengths of 10mm and 20mm along with some 100mm lengths of wire.
Hello nam
I am east of the CT river, in East Hartford.
Cheers,
Thom
Thanks everyone for these suggestions! LHS aside…I now have greater sources and references!
