Mesh and Warrior MCV
can any one help me with tips on glueing with out damageing the mesh or tank lol thank you
Pantherart, If the mesh is metal (Photoetched), you only really have one option, and that is superglue (although epoxy would work too). If plastic, you can try ‘normal’ liquid glue but it might not give you a strong joint… Superglue would be the type of glue I’d use…
You’ll probably find easier to paint the tank and the mesh separately, and do a final assembly just before applying the last touches of your weathering (such as pastel chalk dust). Decaling, washes and dry-brushing should be done prior final assembly, to make things easier and limit the chances of breaking things…
Superglue might give you a few shiny spots. Let the glue dry then ‘cover’ the shiny spots with a touch of paint/weathering.
Hope this helps!
djmodels1999 oh ok thanks i think its plasic as its the mesh for the model Warrior acadmy kit i all whays seam to make a mess of the mesh
Just take it easy. Actually, I have that kit but have never looked at it! If the mesh is already pre-cut, just use cocktail sticks to put little dots of superglue, and apply the mesh over the dots of glue. Use another cocktail stick to press the mesh onto the model. You may want to scrape the paint a little bit first, where the mesh will be glued on, as that will give you a stonger joint. Then when everything is dry, use a bit of paint to cover up the glue and other areas where the plastic is still showing through.
lol funnie how things work out sometimes you wouldnt have any photos of the Warrior as it only has the un or german decal
Here’s a few links with a few pics…
http://www.d-2-128.org/armorid/warrior.html
http://www.henrikc.dk/militaryvehicles/details.asp?autono=79
http://www.geocities.com/Pentagon/Quarters/7413/warrior.html
Pantherart. Welcome to the forum.
I have several pics including close ups. Send me an email (click on Email under my sig) and I’ll send them to you.
Welcome to the forums pantherart and good luck on your model.
mark956
thanks every one ill do my best just wished i had a airbrush to do even bettere
I just purchased a Badger 155 anthem air brush from www.dixieart.com . It cost $66.00 USD. Any order over $48.00 dollars and shipping in the lower 48 states is free. Sweet deal in my book.
mark 956
petbat my probly is that i cant log in properly for some reason i can post hear but i cant totaly log in and have my name on the page and dont no how to fix it but my email is panthernz@xtra.co.nz
