This will be my first full build log on here in a very long time and I hope you will enjoy this as much as I will.
Meng’s Tiger II along with the interior set, zimmeritt decals and track/suspension set has been sitting quietly in the stash but in quiet moments you can hear the whisper “Build Me! You know you want to!”
Having had to take time away due to a slight meltdown and heart issues (again! This is getting tiresome!) Meng’s Panther A was a nice way back in and it does feel good to actually finish something!!
Meng’s Tiger II with internal detail is a different beast to Takoms one in that they have not only produced a fabulous accurate interior but also they have thought about display options too and the enterprising modeller will be thinking long and hard about the end result before starting. I have!
Having played with the main parts of the kit the engineering (and detail) is fabulous, and everything seems just to nearly clip in to place.
THis is a first batch release and so has a metal barrel included in the exterior kit. A very nice extra.
On the interior kit. the detailing is a bit soft on the ammunition and so I contacted Eureka XXL and made arrangements to purchase a full load of ammunition from them with a mix of the 4 types of ammunition that was available for the 88mm.
When attached to the cases…
The German army stopped using brass for their cases in about 1938 and moved to steel cases which were parkerised and painted. THere were quite a few colours used including green, grey, silver Clear laquer over the steel, copper, bronze etc and I will choose 1 colour for each type of shell for the case. This was not done in real life, but in this instance it will show the different shell types more effectively in the racks. There are decals for the shells and cases in the kit but I haven’t counted up and will contact meng to purchase an extra set if they will allow it!
The track snd suspension set was a bit of a non starter for me when I investigated it. the “working suspension” is already in the interior set and the tracks ars plastic which need much cleaning up, guide horns attaching to each one and then fixing together with very small pins which are easilly lost or in my case will go pinging off into the distance followed by a string of very naughty language.
That set is now discarded and in come a nice set of Friul King Tiger tracks! ![]()
There is a lot of detail in this kit and detail on the detail and so I’m not putting a time frame on the build as I will work on it when I feel like it. I will probably jump around the kit a little too which helps to keep the interest going.
I intended originally to recreate the picture of the Tiger II in Budapest 1944 during operation Panzerfaust to which I have the zimmeritt decals. Since then I have decided to recreate one of my recovered Vehicles, a Tiger II from the Panzer Division Munchenberg, Seelow Heights, 1945.
Next time, pictures of the dry fit test to see just how the major components fit together.
James
