I just picked up an ME-262, got home popped open the box and looked over the instructions and it says that the cockpit is german grey. I don’t have it. I have looked at a few websites and no help there. My question: What color, Testor Model Master, is close to german grey or what can I mix?
If you can’t find it, I did mine using an engine grey from modelmaster. It is on the dark side but looks great!!! If you picked up the Tamiya kit, 1:48, you are in for a thrill. It is a great model, especially the little tractor that comes with it. Have fun!
Ditto on the black-grey 66 interior color. Check out the following references;
Messerschmitt Me-262, MBI, Czech Republic, Miroslav Balous author
Me-262 Stormbird Rising, Osprey Aerospace, Hugh Morgan, author.
Luftwaffe Colors vol 3, Monogram Publications
If you can’t put your mitts on these, I’ll e-mail detailed interior color information to you.
I have over 30 years of publications catalogued by aircraft (sorry , hand written on index cards) so it is no problem digging out the info.
Testor’s gunship gray is almost an exact match for the gray that is used in the cockpits of WWII Luftwaffe aircraft. A long time ago, my dad had airbrushed the cockpit to one of his 109’s the correct RLM color match and just out of curiosity sprayed another gunship gray. The result- you can’t tell the difference! Ever since then he and I use gunship gray in the spray can for the base color for our German airplanes. I think it would be the best way to go.
I use Model Master RLM66 for most late model Luftwaffe cockpits then dry brush with a slightly lighter gray to bring out raised detail and give a little weathered look.
