I am presently getting ready to build the Canadian icebreaker Norman Macleod Rogers in 1/72 scale. It had a MBB BO - 105 helicopter on board. Does anyone know if there is a 1/72 scale model kit of this chopper out there somewhere? I am not too bad at scratch building model ships but scratch building a helicopter??? …Not so good… in fact pretty damn grim. Even something I could perhaps convert would be a help.
Any help about this helicopter would be appreciated.
I found a source for two MBB BO -105C Airfix models (1/72 scale) which I will be getting as I may do more than one icebreaker. I haven’t even started assembling the hull yet ( just have the frames and keel cut out) and already someone wants to buy it when I am done. Don’t know if I really feel like doing that as then it becomes a “JOB” and not a fun pass time
What is the difference between the 105 and the 105C models?
I also found out that another helicopter that was used on this ice breaker was the Allouette. I found some of them in Squadron.
There are two fuselage lengths for the Bo105 the standard 105 is the shorter fuselage while the 105CBS is lengthened by 12" so it can accommodate a larger stretcher unit.
The easy way to tell them apart is that the CBS has an extra window behind the rear cabin doors. There were other minor changes, but that is the big tell.
That helps. I wonder if I can shorten the Airfix model as I want a MBB BO -105 not a MBB BO-105C. The other option is to use an Allouette helicopter that was also carried by the Norman Macleod Rogers.
Or I could follow the philosophy that “a blind man running for his life won’t see the difference” and just use the 105C.
