Hello all,
I finished Book 1 of the instructions for the 1:96 Revell USS Constitution. I thought I did a pretty good job of following the instructions step by step, and the model looks great so far, but am wondering now if I might have made some mistakes that have turned into big “gotchya’s”. Its taken me about a year to get the model to this point, and I was ready to start the rigging until I notice some big issues.
I turned the yards on the masts at an angle as per the instructions suggested so that I could rig it with sails. Now I find that the ratlines don’t seem to fit properly on the angled side of the fore and main masts–they seem like the only way they will fit properly is if they are jammed into the lower yard. Has anyone else encountered this problem? Is there a solution?
When I insert the masts in the deck, it appears that the mainmast is misaligned–it is slightly tilted to one side. I am not sure how to correct that other than to get a circular file and enlarge the hole on the lower deck to make it stand straight, but this will make that hole bigger and I assume make it difficult to cement the mast in firmly. I had a heck of a time when first building the hull to get the lower deck sections to align properly. I thought I did a pretty good job of it, but perhaps this is why I’m having this problem. Not sure what to do next to correct it.
At what depth do the bottoms of the masts insert into the ship? I would assume they go all the way through the lower deck until the bottom “ring” on the mast is flush with the upper deck, but the instructions do not tell you. The fore and mizzen masts seem almost impossible to insert them at that depth, and when I test fitted the ratlines I found they fit best when the masts are NOT that deep. Not sure how to proceed.
I am not a beginning modeler but am certainly not an expert modeler either. I’ve been taking my time and patiently wading through each assembly step carefully, and so far she looks pretty nice–then seeing I’ve got a misaligned mast and problems with the ratlines not fitting into the angled yards took the wind out of my sails–pardon the pun!
There is little I can find on the internet to answer my questions. Any advice from someone who has found these same problems or who might know how to fix them would sincerely be appreciated!! Thank you!!
