Masking with newspaper?
Another newbie question here. I’ve read several posts here that make reference to masking with wet newspaper. Can somebody tell me how this is done? Does it work well? Doesn’t the newsprint get on the model? Doesn’t the newspaper absorb the paint being sprayed?
Thanks,
Rich [8D]
HI Rich!
Believe it or not, I’ve used this technique with good results. Haven’t done it for a while but it is a valid method. I used it a lot when working on a plane with a natural metal finish. I’d cut some patches of newspaper, block off a panel which needed a different shade of NMF and use the airbrush to apply the different shade. It’s pretty much as easy as it sounds. I’d get a bowl of water, dip the newsprint in, then lay it on the plane. Before spraying I’d dab away the water because you don’t need to have the paper sopping wet. If the paper is nicely damp (and not sopping wet) then it actually dries sort of quickly so you have to work with a little (not a lot though) of speed. You don’t have to rush through it, just use common sense and don’t leave the paper on for half an hour while you do something else. The paper won’t absorb or “wick” the water away from the area which you are trying to paint. Just think of it as being the same as using tape only the “tape” is slightly wet. You shouldn’t get any newsprint on the model but if you notice any then a wet paper towel will take care of it. It’s actually a great technique! Hope this helps.
Eric
PS. Now that I think about it I used this method on my B-36 when I had large areas to mask off and didn’t want to use tape which could have marred the metalic paint.
I used to deliver papers when I was a kid, and the pressroom always had roll ends with a few feet of paper the width of a double newspaper page left on them. I used to get them all the time to draw on, make paper planes out of, etc. The nice thing was that they hadn’t been printed on yet so no ink!
That was 30+ years ago, but my guess is that if you can get into one of them to ask someone they would probably have some you could have.
I use newspaper both wet (damp) on NMF and dry in masking off large areas of multi-colored models. Works pretty well for me.
