Masking agent something new?
Hey good to be back have a question has anyone tried that masking liquid it’s in a tube you squeeze it and apply it to what you’re masking use a tooth Pic to put it where you need it. I was just wondering if anyone else has experienced this stuff I forget the name of it
Welcome to the forums.
As for masking fluid, it’s been years since I’ve used it. The first mistake I made was using it over matt paint. It did not come off easily and it removed some of the paint underneath. I never used it on a painted surface after that, so I have no idea if the results would be different on gloss paint.
I’ve used it a couple times since for masking canopies and other clear parts like marker or brake lights on car models. It worked fairly well for that, although I found it harder to get a defined line or demarcation line because it’s difficult to see as it dries.
I’m not sure how the newer products stack up to the older stuff I used. Hope this helps a bit.
Thanks for the reply I’m not exactly sure what brand it was I know it was a blue colored tube that’s about it
Which company makes the masking fluid you are trying to use? I’ve had some success with Vallejo but I have found that using Vallejo masking fluid with Tamiya’s tape works well for me. Something to consider.
I hate masking :rofl: but when I have to do it I just use painters tape and sometimes a bit of clear on the tape edge to seal it. I have not tried any masking liquid.
