Martlet WIP
I’m doing this one for a Grumman GB on another site, just wanted to share and get some feed back. I started with Tamiyas 1/48 F4F-4 and as this is my first attempt at a conversion I’m keeping things simple. As near as I can tell most of the differances are in the cowl, prop. hub and engine. So thats where I’m focusing my efforts.
Started by opening up the cockpit floor.
Next, I corrected the prop. hub with styrene and milliput.
The engine magnetos needed to be removed, so that was next. Also added PE wires and copper wire oil line.
Ok, what now. Oh, yeah. Cowling. The martlet had two large flaps as oppposed to eight small ones. So out comes the putty and wine bottle foil. I also removed all three intakes.
Here are some pics of the mostly finished cockpit. A combination of kit, resin, PE and scratched pieces. Still needs touch up, washes, dry brushing ect…
Let me know what you guys think. Any and all comments, critiques and questions welcome.
I can’t really offer any criticism due to the fact that everything looks gorgeous !
Crazy detail - Nice job on the prop modification - and that IP is really nice.
Chris
Your work looks great so far!
Which Martlet are you doing? It makes a huge difference in the conversion.
From the F4F-4, to convert to a:
Martlet I = Wright Cyclone (9 cylinders in 1 row) with Hamilton Standard uncuffed prop; short chord cowl and no cowl flaps; fill the wing fold lines; fill the “middle” gun panels as this aircraft had 4x.50, but in the inner/outer locations; retain the cowl scoop.
Martlet II = P&W Wasp (14 cylinders in 2 rows) with Hamilton Standard uncuffed prop; long chord cowl as on -4, but with a single wide cooling flap on each side; no scoop on the cowl; all 6 guns in a folding wing.
Martlet III = F4F-3A; non-folding wings; 4 guns (inner positions so fill the outer panel lines); cowl scoop; single cooling flap; Curtiss-Electric cuffed prop.
Martlet IV = Martlet II but with a Wright Cyclone engine and short chord cowl.
Martlet V = FM-1; from a -4 just fill the outer wing gun panel lines.
Martlet VI = FM-2; major surgery from a -4 with tall tail; “jet” exhausts; and remember to fill those outer wing gun panel lines.
As you want to make this simple, I assume you’re doing the Martlet II, given you’ve modified the prop. Don’t forget to remove the cuffs. If an “early” II, then the pitot is different than the -4; it sort of looks like an upside down L on the top of the wing.
Tim
This is some spectacular work! Your additions really add an element of realism to an already excellent kit. [tup]
Nice Cockpit!
Very nice work so far [tup]. Keep us posted.
Regards, Rick
Thanks for the kind words fellas. And yes, Greenshirt, I am going for the Martlet II, so thanks for the heads up on the cuffs. That I didn’t know.
Well it took me long enough, but here is the finished Martlet II. In addition to what I’ve already shown you I also cut and reposistioned the rudder and rear landing gear. Scratched exhaust pipes with wine bottle foil and moved the pitot tube to the upper wing with a scratched piece. Added brass tube guns and stretched sprue antenna. Painted with Tamiya acrylics and used Aeromaster decals. I weathered with tempra sludge washes, oil washes and Tamiya smoke. Any and all comments and critiques appreciated.
OMG, we’ve got a winner here![;)] Outstanding work and a superb model. Really like everything about it. Congratulations[bow]
Richard
Fantastic build.[#toast][#toast] Only happens in my dreams.[sigh]
Jim[4:-)]
This is top notch work ! You can be justifiably proud of this one. [bow]
Yes, very nice work indeed! As much as I love a blue Wildcat, seeing one in FAA livery is truly a treat for the eyes. Well done! [^]
Very impressive. Thanks for sharing.
[#ditto]
Double [#ditto] !!
Excellent Build [tup]. Thanks for sharing.
Regards, Rick
Very nice work… really like the weathering!
That is just outstanding work, well done![#toast]
Thank you gentlemen for all your kind words.
Great looking build.[tup]
The weathering is spot on.
Just wouldn’t look right in blue!
Karl
