i’m going to start a new dio that i’m going to have to have big waves but i have no idea on how to do or where to find the ref mat needed i’m sure finescale has done a segment on this issue but i haven’t a clue your help as always is greatly appreciated,and thanks[8D]
Read directions on bottle or box the water your using has on the labels…When in doubt read directions!.. Hope that work’s ha,ha…[censored]%^$%$@@( ^%$(
Not being a smart aleck, but the directions will guide you through the whole ordeal…
“RC”
Read Jeff Herne’s article on making water on SteelNavy
http://www.steelnavy.com/water.htm
as well as Rusty White’s article, also on SteelNavy
http://www.steelnavy.com/Whitewater.htm
There was an article in a recent FSM which I belive used Celluclay (a papier mache product) to build the seas. That process is similar to Rusty’s method. Regardless, you need to do the painting outlined in Jeff’s article or you end up with a blue-painted block of something which is supposed to be water
