I have a question about diorama bases. I need to know what is the best thing to use to make the terrain on a base? I have heard of using putty, before. Is there any other one I should know about that is better?
Another vote for Celluclay, mixed withliberal amounts of brown craft acrylic, white glue and textured turf material and just enough water to get to a thick oatmeal coonsistency. If the ground work is to be built up more than a half inch, use layers of styrofoam first.
This is very true especially when you are trying to make a hilly or highly irregular terrain. I on other hand (due to the fact that celluclay is rather rare here) use wall putty to top off the styrofoam.
You can use wheels or extra tracks to make impressions on the wall putty before it dries.
On my single attempt (so far) I used a styrofoam block and carved it in a wedge then wrapped with paster bandage stuff, painted base color and textured with woodsland products, ballast, rough rock and then some stones. I like the idea of tha oatmeal mixture, sounds like something to try on future projects.
Just to be clear, the Celluclay mixture has the consistency of thick oatmeal. This is a reference point for you. There is no oatmeal or other fod product in it, just Celluclay, White glue, acrylic paint and ballast.
Someone else mentioned sand, glue and paint. That would work on for a perfectly flat result, but hanure doesnlt provide many perfectly flat surfaces.You’re better off and more realistic having some mild organic curves to the base.
Just use Elmers /water mixtue. Not too thin or, like Aj said, it’ll really flatten. Create some topography by gluing styrofoam to the base first. Small hills, or build up a road.
Use cheap acrylic paint like Anita’s or the like. Cheap at Hobby Lobby or Michael’s. I’d get Burnt Umber, Coffee Brown, earthy colors. You don’t need much in the mixture, you could always paint it when dry.
Just to clarify, the dried result sholudn’t be left alone… you’ll apply dirt, dust, grasses. You’re just providing substrate.
Elmer’s white glue is actually poly(vinyl acetate)also known as PVA. It is delivered as an aqueous emulsion (which is why you can dilute it with water when it is still liquid) and dries to an almost insoluble film after the water evaporates and the polymer micelles join.
There are many other glues that are collagen based made from: parchment clippings, rabbit skin, hide, boiled down horse remains, bones etc. One common household form of this is gelatine.
