I have been working on a new conversion for a little while now. I have thrown together a concept M6A3 Linebacker, a.k.a Bradley M-SHORAD (Mobile - SHOrt Range Air Defense). So far, this is a concept vehicle by BAE that the US Army hasn’t bought…yet. I hope they do because SHORAD systems are woefully lacking in the US Army.
The actual vehicle.
M6A3 - M-SHORAD 5928×616 143 KB
M6A3 - M-SHORAD 2925×617 138 KB
It uses the .30mm chain gun from an Apache, Stinger pod, and all sorts of sensors and jammers.
It is a franken-Bradley of sorts. I used the Academy M2A2 OIF kit as a base, added the Magic Factory M-SHORAD parts and CITV (left over from their M2A4 and M2A2 ODS respectively). I also added some extra parts from a few Orochi M3A3s sprues I had bought, Jacques’ 3-D printed suspension and a few other of his detail parts, ands some scratch parts.
You can see up top I added the additional A3 hull armor plates from some modified Orochi parts. For the added armor around the base of the turret, I used the tops of a couple interior turret walls from a Tamiya interior.
IMG_20240629_1449459291920×1440 195 KB
I used the Magic Factory A3 ramp and Jacques’ tail lights. I also cut the Academy rear plate wings off and flattened it out, along with cutting the hull top to fit. Lastly, I added my own angled plates behind the rear stowage boxes.
IMG_20240629_1449293901920×1440 181 KB
IMG_20240629_1449188511920×1440 144 KB
IMG_20240629_1449413261920×1440 138 KB
On the turret, I added the Magic Factory M-SHORAD parts. They fit the Academy parts perfectly. Most of the needed parts are all on the C sprue. A few common parts are from the Academy kit. The CITV also fits without issues. I made the added turret top armor by tracing the Magic Factory kit part onto 0.020 styrene sheet and cutting it to fit. I also used the new GPS, newer hatches, and some other detail parts from the Orochi sprues.
IMG_20240629_145701896_HDR1920×1440 117 KB
IMG_20240629_1450364411920×1440 138 KB
IMG_20240629_1450465401920×1440 98.2 KB
IMG_20240629_1451567841920×2560 275 KB
Here it is all together.
