m1046 question
are there m1046s hummers in oif (if any) with up armour kits? if there is could i use blast model armoured door kit?
also is SINCGARS the current radio in hummers?
There were M1046’s uparmored early on, most have been swapped out for vehicles with MGs as opposed to the TOW on top though. The MG is more useful in an insurgency.
The Blast half-doors represent ones used early on in the insurgency (late '03 - early '04) when home-made armor was being used. It is possible that some M1046 TOW HMMWVs had these type doors along with other pieces of steel plate for armor.
The SINCGARS is the current radio being used, along with TACSAT and Harris long range radios, but they all look similar and fit into the same mounts.
Aren’t some of the “Digitized” Divisions useing ASIPS? I guess it could be called SINCGARS also since the nomenclature is RT-1523E, if I remember correctly.
is pro arts SINCGARs kit a accrute kit?
Where there sand colored TOWS hmmwv’s in oif?
only pics i can find where 3 tone camo ones
ASIP is a type of SINCGARS. The older, larger RT-1523 is an ICOM model. ASIP is the smaller, newer version. All units are transitioning to ASIP, it has nothing to due with the digital division. We transitioned to ASIPs in 2002 in 3ID.
Yes, it is a very good set. It includes both ASIP and ICOM SINCGARS as well.
Yes, both 3ID and the USMC had Sand as well as NATO camo M1046 TOW HMMWVs.
is there any USA online shops that sell proart and is reliable or do i need to order from proart site?
http://www.blast-models.com/
