Losing the battle tonight with my airbrush and AK Interactive Matte Varnish #775 (ACRYLIC)
Hello all, Mods feel free to move this if need be, but this forum gets the most traffic… I lost the battle tonight trying to spray some AK interactive acrylic "matte varnish #775, I shook the bejesus out of it, and added to airbrush with a tad of AK interactive #712 “Acrylic thinner”. I was spraying out of my new Paasche Talon airbrush with mt Paasche D3000R compressor. After a short gander on AK interactive’s website, I could not find the recommended pressures to spray said matte clear. So I started around 22 psi, and it sprayed ok for a few seconds, then clogged. I for a couple times after that, I could put my finger over the needle, and “backflush” into the color cup, and get it working for a couple more seconds, then it just flat-out clogged. I emptied the cup, tore the airbrush apart, (basic disassemble) put it back toghether, then tried 30 psi, thinkinmg maybe I wasnt high enough on the pressure for the clear. Same results, Then, it started bubbling around the trigger when I tried to “backflush” it, and then I beleive the clear stuck the air valve OPEN. I took the airbrush apart, soaked everythibng in acrylic thinner, same result. Would work breifly, then reclogged, then the air valve stuck. Since I am new to airbrushing, I have some questions and will take any other feedback you have to offer. This was my FIRST attempt at using acrylic clear, not so good results. The brass allen setup on the bottom of the air valve is garbage, I must say. It stripped out pretty quickly, and I had to destroy the chrome plating on the air valve body to get the bottom off to get access to the valve and spring. It leaked air after reassembly of these parts at the bottom, closest to the air supply. This airbrush is only 4 months old, and this is my third or fourth use.
  1. Is “back-flushing” in this manner BAD for the airbrush, or did it contribute to the airvalve clogging? (I will guess yes, since it seemed to get the clear into where it wasnt supposed to be?)
  2. If you have used these AK interactive products, what kind of PSI did you use, or what results did you have?
  3. WHAT ELSE can be used to clean up airbrush and related parts after acrylics other than water, and the $9/bottle /60ML acrylic thinner?
3 should spraying acrylic matte clear be this much of a PITA? I got my butt whipped tonight…
I was trying to finish this 1:48 PBY Catalina as a gift for my barber whose father served as a crew cheif on one in the pacific, as a sub-hunter…I want to get started on my 1:48 B-29 superfortress for the Boeing GB!
THANK YOU for your help!!
RUDY
  1. It’s won’t do any harm to the airbrush & is quite a normal / regular thing to do. Is it possible that when back flushing some paint got from the cup into the trigger area & consequently onto / into the air valve?
  2. haven’t used AK
  3. Strong solvent / cellulose thinner is an excellent cleaner, but shouldn’t be put near any seals that aren’t PTFE (PTFE seal are white, others are black) as it will swell & eventually deteriorate them - If I have an issue & suspect it’s paint blocked somewhere I will strip the nozzle & air cap & soak these in cellulose thinner. Regular airbrush cleaner or isopropyl alcohol should be fine for the rest of you cleaning.
  4. Just like airbrushing anything, thinning & drying can be a problem.
It sound’s very much like you are suffering from tip dry - reducing pressure and/or adding a retarder will help to avoid tip dry, AK do their own brand retarder “AK Interactive drying retarder”
Let’s not forget the needle pressed too much to the tip - thus closing off the airflow. I agree with above poster regarding the seal but I find it hard; yet doubtful the seal going bad after 4 months of use.
Couple of things… 20 psi seems like a lot but might be all right just experiment with it. I almost never look at my gauges they lie anyhow.
Do you have a dryer / filter in the air line?
Many matte laquers do not require thinning and in fact warn against it. Too much thinner and the stuff dries out before it even touches the intended surface and as you found out will collect on the tip making a mess of things. Once it does get a glob on the tip, just pinch it off with a damp cloth and fingernails. Careful of course not to bend.
What was the humidity / temperature conditions when you were trying.
Good old laquer thinner from the hardware store works well for cleaning. Also get a set of brushes intended for the task. As mentioned before do not let it sit in the thinner sit overnight as it can get after the plastic parts in there.
Backflushing is actually a good idea. I do it after every color change / cleaning.
A side note, I hardly ever break my airbrushes all the way down for cleaning. In fact I consider withdrawing the needle a drastic action. If I do get tip dry I simply ‘pinch’ it off with a damp cloth and fingernails. I also keep an old tooth brush handy to clean the face of the brush occasionally.
Invest in some quick disconnects. You will thank me [;)]
Maybe once a month or every other month do I do a full break down of the brushes.
Thank you for the replies and help. Yes, my compressor has a water separator right on it. I first tried spraying the Matte varnish right out of the bottle, as it seemed to be a good consistency to spray out of an airbrush, and it said right on it “brush/airbrush”. I do have a quick disconnect for the brush from the air line. When I tore it apart, it seemed as if the Varnish had turned to mucous-y thicker snot consistency, and that is what was clogging the brush. I could occasionally see the stuff coming out between the brass nozzle and the needle, but by the time I discovered this snotty stuff, the air valve was stuck wide open, and it seemed no amount of thinner and cleaning was helping it. When I finally destroyed the chrome finish taking the air valve apart, and cleaned it on the inside, it worked for a couple sprays, then the air valve got stuck wide open again. It also had a minor air leak after I put it back together, and the brass Allen screw that is the bottom of the air valve promptly stripped out as well.
Needle was not too tight into tip, moved freely. Humidity was low, inside the house with the AC on. When it did spray, it would sometimes spit foreign stuff out with the clear. I had sprayed flat black Testors acrylic paint right before, and the brush worked fine…
Thinking of using a tiny bit of anti-seize for the air valve assembly, where it attaches to the brush, so if I need to R&R it in the future, it actually comes apart, without the use of vice-grips! I think it is kind of stupid they do not put any flat surfaces on the air valve assembly for you to grab onto.
Anybody else? Seems like I’ve had way too much trouble for spraying expensive “varnish” that should be ready to spray right out of the bottle, after a good shake. On a side note, the spots where it did spray, were flat just like the paint, and you cannot really even tell where it was varnished/unvarnished. I like the results, but the spraying was a major PITA.
Thanks, Rudy
Rudy I don’t know what else to say other than it sounds like maybe you had a bad batch of varnish or it was thinned incorrectly, maybe you had a little water in the brush from prior cleaning, maybe there was some water in the mixing cup, hard to say.
I thought about the back flushing comment and forgot to mention its a good idea for gravity feed brushes but not so much for siphon feed.
ps; I really don’t think the air valve assembly is the culprit unless it was bad to begin with. I don’t think I have ever removed an air valve… ever.
Thank you for the responses UlteriorModem… I am not sure why the air valve decided to take a dump, but I don’t think the gooey varnish getting in there helped at all. Im hoping the new parts should be in today, so I can finish the job and post some pics of the plane, IF you guys promise to take it easy on me;) I also have a bottle of Vallejo matte varnish… Not sure if that is the same company or not, I cant keep track of the mergers, and people breaking off, etc…
Thanks again, Rudy
I have a small bottle of the Vallejo varnish but have not tried it as yet.
In the meantime I have been using this stuff
www.amazon.com/…/ref=sr_1_1
With decent results. Long drying time though 12 hours between coats is recommended.
Rudy, just wanted to touch base to see if you were able to solve your problem with the Talon? I just ordered a Talon for myself and wanted to see if anyone had any comments about the performance. I have been using a cheap Master dual-action as my first airbrush for the past year. I didnt want to go out and spend a lot of money on a good quality airbrush until I knew I would be able to use one. Do you have any pointers or tips that I should be aware of?
Rudy
Was this AB brand new? It sounds like the needle bearing seal was bad and allowed paint to leak back into the trigger and air valve. The same thing happened to me with a brand new Badger Patriot. The needle bearing also went bad in my Badger Renegade which was sent back for repairs. The paint leaked into the rear of the AB making the trigger stick and the air valve jam up.
If its new I would either take it back where you got it or see what Paasche’s warrantee says.
For the down time, I purchased an Iwata Neo at Hobby Lobby with a 40% coupon that cost me $47 and I’m very impressed at how well that inexpensive Neo performs. The trigger is silky smooth, the paint chamber design makes it a snap to clean and it produces fine pencil lines at low psi.
In my experience, Vallejo & AK don’t spray well. I have to really work hard to get them to spray well. So I no longer spray them. In contrast, Tamiya & Testors acrylics always work for me regardless of the thinning ratio and regardless of psi.
For some reason, MM acrylics don’t spray that well for me but the Tamiya paint seems to spray almost as good as enamels for me. I have several Vallejo paints for hand brushing and have heard that they do not spray well with the exception of their Model Air line.
WHEW what a PITA you’re having Rudy.
I empathsize with all your AB problems. I have a Badger Patriot ( my main AB ) a Pasche VT and a no name cheap one from Harbor Freight and none of them has had the problems that you are experiencing.
I always use Testor’s Dulcoate/Glosscoat for my clears. I always run 2 cups of hardware store laquer thinner thru the brush after painting and only occasionally hafta disassemble for a thorough cleaning. I have not had any problems with the seals breaking down with the laquer thinner.
Seeing the problems you’ve had with AK , I’ll stick with the testor’s and thank you for the informative post.
I’ve never had problems using Model Master acrylics with an airbrush. Maybe you’re not thinning it enough or thinning too much.
Rudy, bet there were forehead marks on the wall.
As mentioned, backflushing won’t hurt the A/B. It does however put air into it, which will accelerate the drying process.
I don’t think you got a “bad” batch of varnish, that’s usually just a problem from aging paints on the LHS shelf and I can’t imagine that your AK Varnish is old.
I am going to guess that humidity is a factor, which you can measure by how often you empty the water trap. The house A/C won’t have an effect on that.
I dindt have any issues with the MM acrylic paints, they sprayed fine. It was the AK Acrylic “matte varnish” that gooed everything up. It was the 4th time using the airbrush, so I am really not sure what the issue was. I ended up using an ez-out to remove the broken nozzle threads, but there appeared to be some left in the brush, and with the long (too long really) EZ-out, it appeared I tore up the inside of the brush a bit. My impatience I guess, Paasche said to send it in and they would replace it. I had already tore it up at that point, so I just bought a new one. (like I am “made of money” or something?!?) It really isn’t that bad, it ,may seal up and spray fine, but I didn’t want to risk it. Oh well, now I have extra parts :slight_smile: Paasche customer service was quite friendly and easy to work with. I went with them for being “made in the USA”, I am not sure if Badger or which other makers are as well. Hopefully I wont have anymore issues, I’d like to find an acrylic flat “clear” that sprays well. Thanks for all the help and info-
Thanks, Rudy
I use Model Master acrylic clear, thinned to about 50%, and it sprays wonderfully with about 20lb PSI. Seriously, give it a shot.
Thanks Karl, I’ll give it a shot. I have used the MM Lacquer flat clear, but it seemed a bit “glossy” for my liking…
