In particular with what looks like a depth charge deployer.
I’ve been working on a 3d design of v-69 a WW1 German torpedo boat and am trying to model the stern but can’t really make out exactly how it was put together and worked.
I know this is a long shot but…
If anyone has clear (or clearer) pictures or diagrams that could help me, I’d really appreciate it if you posted them. Heck - even a description of what it was and how it worked would be helpful!
Below are the best pictures I’ve been able to find on line.
The first is of the v-69 the others pics are of other ships also of the v-25 class.
I think the mystery device is a depth charge deployer, looks like a swiveling conveyor belt that that seems to integrate with a deploying platform just behind it somehow (looks like the two are connected in the top down picture) How would that work when swiveled to extreme left or right? Lots of questions and no info…
I kind’a wondered the same but wrote it off thinking the big round naval mines I imagine when ww1 naval mines are mentioned, would never fit on that device. After reading your post I decided to google “WW1 German naval mines” and found this image:
That looks very much like the cylinder-ish objects strapped? to the sides of the device I’m trying to model. So it probably is a mine laying device, I’d still would like to see some much better quality pictures on the off chance that anyone has them or knows where some may be online…
I will try googling verieties of: German torpedo boat mine laying equipment
This is the kind of thing that drives me bannanas…
Look at pic 1 above, look at the lefthand botton of the device in question, rounded right? Now look at its refection in the water below - Flat and square.
How is that possible?
I captured that still from a youTube video, so editing is not likely.
Floating naval mines are strapped to their anchors, which are typically squared off and fitted with flanged trucks like railroad wheels (or in a sheave-like configuration).
WWI mines are not always round, many are cylinders so as to have an air chamber for bouyancy.
Depth charges in WWI are typically launched via a mortar using black powder. The charges were large, often 250 or 300 KG and the vessels were slightly built, not a good combination for close-aboard underwater detonations. (Submarines did not operate that deep in WWI, so the explosions were very close to the surface.)
Thank you both for your replies - I’m now reasonably convinced the device in question was indeed for deploying mines and not depth charges as I originally though. It’s shape isn’t consistent between photos I have of it, I’m guessing manufacturers varied the design over time. At it’s seaward terminus some photos show it rounded others squared, all seemed to be able to rotate to port and starboard and have some type of conveyor belt. Would love to get my hands on a diagram…
Who would have designed or built that boat? Could there still be records of it in Germany? They had a habit of maintaining all sorts of records for ships and equipment throught he decades.
Per Wikipedea: AG Vulcan went under between the world wars. A new Vulcan shipbuilder took over the old yards but had no connection to the prior Vulcan company other than name and location. Wouldn’t begin to know who owns the rights to those old plans now - may poke around German government archive type sites - though mein Deutsch ist verboten!
You might get lucky. I think there are some researchers over there that try to keep track of U-Boats and other wrecks that do speak English. There might be a translater tie in on their computer, and even if they don’t, just getting something in English shoiuld make them curious enoiugh to translate. You have nothing to lose.
With the EU over the past years, a lot of German citizens and companies are English speakers.
Try the company and they might know if any records survived the war, or be able to send you in the right direction. Imperial War Museum/archives might be the best bet
Typically just rails, either bulb-top “T” or full round fixed to the deck.
Dedicated minelayers have a “downhill” slope at the end of the track. So, you roll the device on its wheels to the end, and put it on a stop chain. Then, when the bridge office indicates, the pelican hook is opened and the device rolls over the stern. The 15-20 deck apes hunkering about on the Sea Detail, then heave the stack out so the next one is ready in the stops.
This can alternate port and starboard to need.
Unlike in the movies, where the things are strewn about willy-nilly maybe 300-400 feet apart. You lay mine fields in a grid about around the length of the target vessel. So, they are laid around 300-400 yards to around 600-800 yards apart. The spacing also needs to be wide enough that the devices do not foul each other due to currents & tides, or storms.
The minelayer will get to the end of the line, and turn down the last line run, and make the next grid line. Floating mines stay attached to their anchor by way of a salt plug to keep the field “safe” until the minelayer can get out. There is some considerable navigation required to lay the grid lines.
