I want to buy a model of something that has a MG or anti-tank gun or both. There is one particular one I am looking at. It’s a Dodge 37mm anti-tank vehicle used in North Africa (1/35th scale). The only problem is that I can not find any site or store that sells it! Anyone know of a site that I could buy old models on? Any good 1/35th models from North Africa you all know of?
The kit you are looking for is an old Peerless Max / Italeri piece.
Internet Hobbies lists it but I’m unsure of availability.
http://www.internethobbies.com/internethobbies/it135dodm6w3.html
The truck is buildable, but the gun is on the rough side. It will take some scratch work to bring it up to snuff.
thankyou everyone that replied. I saw that model on that site because I want to build one, but it didnt look like you could buy it.
Italeri sells a Demag with a Pak 40 mounted on it. I doubt it was used in Africa if that makes a difference. Tamiya makes a 251 halftrack with a 75mm howitzer.
Revell makes a British Bedford truck with a 6 pdr in the backused in North Africa, its a decent kit, i’ve seen the dodge kit around in an Italeri box in a hobby shop but i think its out of production but should be findable.
good luck
wes
wow! thankyou, didnt expect so much response on this topic… thank you for the ideas
