Well I thought I was at the point that it was mostly just building the kit, but as I dry fitted things here I see that the 20mm gun tubs on top of the bridge are in the way of the two kingposts right in front of the bridge, so they will have to be moved outboard some. The plans show it but I didn’t notice until now. The 20mm forward had to be moved forward to be clear of the #1 hatch.
Yes, painting. I have no pictures of these during wartime. The oldest pictures on that German Maritime Commission site are in 1947 when the armament was taken off and they were sailing for Military Sealift. Then they had white superstructures. I am sure during the war they would not be like that. I’ll go with the all gray scheme usually recommended for wartime Liberties. In all the photos I looked at of Liberty ships, only a few had decks painted a different shade than the rest of the ship.
I believe you are correct there .Olympic Steamship Co. Back in the seventies bought some VICTORIES and they had gone to the moth-ball group from the yard .They were all grey too .Deck -house, decks and hull .
I’m all for replacing splinter shields anyways. I usually make a horizontal saw cut across the base, sand the deck down a little and glue on a curled strip of beer can aluminum. Yep gotta take one for the team…
But you’d be moving them too.
Thanks you guys for the clarification on deck color- not too late to correct on my JOB.
The Trumpy JOB is a replica of the ship as she is now. For wartime there are a bunch of changes. There was a thread here on it some time ago. In short, no black boot topping, all the same shade of gray, no name boards ( for security reasons), red anti-fouling only to the 10 ft draft level… Probably a lot more that I can’t recall.
“I believe you are correct there .Olympic Steamship Co. Back in the seventies bought some VICTORIES and they had gone to the moth-ball group from the yard .They were all grey too .Deck -house, decks and hull.”
I have been thinking about what an interesting project this is and what I could do to the JOB model. In the end I think I’ll go stock 1944 because it is a classic, I see her most every day and as noted before, I have excellent access to her.
But, I got to thinking and see that about 2400 of 3200 survived the war, and 800 or so went into civilian service. Over 600 were donated/ sold to the Greeks and formed the backbone of those dynasties. There’s a pretty one on display I think in Piraeus.
"But, I got to thinking and see that about 2400 of 3200 survived the war, and 800 or so went into civilian service. "
Alaska Steam Navigation Company actually converted some Liberty ships to carry containers. The idea of a 10 knot containership with a steam reciprocating engine was not a success.
A couple of this class can still be seen up in Alaska as hulks used for fish processing. The one in Kodiak is the Albert M Moe. The one in Dutch Harbor is now called the UNISEA. I haven’t been up there in ten years. If I had realized this when I was in Kodiak and Dutch regularly I could have taken some pictures.
It turns out I had to move the other 20mm positions too. There is a section of the superstructure I had to add. The after gun positions near the 5 in will also require modifications.
One more pic before I start shooting paint. This highlights all the modifications. I still have to make 12 electric winches and the booms. I don’t know why the decks look tan, nothing is painted yet.
Found this link which shows assembly of P-47s in the field - this gives good reference to how aircraft were packed for shipping overseas. Also interesting idea for a diorama. LOL
By the way, this is the second time I’ve used the Tom’s PE set for the JOB/Brown and some issues to note:
The wires that are supposed to span between lifeboat davits that hold the coiled man ropes and falls are too short. I added a very short length on each end. When you cut a PE railing and you have little lengths of brass scrap? That is enough. Just touch the scrap with CA and stick it on the span wire on both ends. You really only need less than a mm more on both ends.
As noted before, the idea of putting little pulley wheels in the cargo blocks, using slices of plastic rod, just doesn’t work. At least for me.
That short railing that runs in a circle around the 5 in gun mount seems impossible to get attached. Maybe it takes more talent than I have, but i skipped it. I’m not sure it is authentic for wartime anyway.
The stumbling block I’ve run up against now is, a P-38 even with the outer wings removed does not fit in the hatch. No way no how. I thought it could be tilted somehow to get it in there, but when I put in the upper 'tween deck, there is not room to tilt it enough. At the IPMS Seattle meeting somebody told me that they were crated with the engine/tail boom assembly separate. I’ve been looking for a picture of that, so far without any luck. I did find in ‘Army Air Forces in WWII, Vol 6’ a lot of interesting information on how planes were carried. It says these modified Liberty ships could carry 42 planes crated below deck, as opposed to 56 for an escort carrier. But they didn’t say what planes. Obviously, a carrier is way more expensive to run, even if the Navy can spare one. The hatches on these ships are just long enough to take a P-38 engine/tail boom with a few inches to spare.
So now I may just cover the hatches. It doesn’t seem very interesting to look into the holds just to see a bunch of crates!
