The Leopard 2A4 is the Swedish Strv 121. They are the same vehicle but with a different designation.
This means that the Meng TS-16 is the correct kit and just needs painting in 4 shade camo.
The M90 camouflage comprises four colours: dark green, light green, dark navy blue/black and beige
| Color |
Swedish Name |
Yxy color designation |
HTML Color # |
| Dark Green |
Mörkgrön |
5.6 : 0.328 : 0.371 |
404538 |
| Light Green |
Ljusgrön |
8.9 : 0.352 : 0.411 |
525739 |
| Brown |
Brun |
8.3 : 0.357 : 0.356 |
5D4F44 |
| Black |
Svart |
3.7 : 0.310 : 0.316 |
383539 |
RAL 6007 Bottle green -97% match
RAL 6003 Olive green - 95% match
RAL 8028 Terra brown - 98% match
RAL 8022 Black brown - 96% match.
Vallejo are my go to colours as they do not subscribe to the silly scale conversion for paint. Therefore their paint is faithful to the original chipsets. so…
RAL 6007 - Vallejo 71.019
RAL 6003 - Vallejo 71.092 - I probably would consider instead NATO Green (71.093) as it is lighter.
RAL 8028 - No match in Vallejo Model aircatalogue, but NATO Brown (71.249) is probably a reasonable substitute.
RAL 8022 - Again no match, byt in actual fact, NATO Black is probably a good alternative. it is not a true black and has a very slight blue tinge, barely noticable (71.251) also Vallejo tyre black (71.315) could also be a good alternative.
Another member of the forum might have more accurate matches.
If you want to build the new Strv 122 then you will probably need an A5 or manybe Meng’s A7 would be better and change the following:
French GALIX smoke dispensers
different storage bins
thicker crew hatches
Strv 122B, have been equipped with modular AMAP composite armour from IBD Deisenroth to give “360° protection” against threats such as EFPs, rocket propelled grenades and improvised explosive devices
https://thaimilitaryandasianregion.wordpress.com/2016/01/25/stridsvagn-121-and-122-swedish-version-of-the-german-leopard-ii/
I would consider Mengs A7 and altering it for the 122b
http://www.meng-model.com/index2_new.php?id=303
James
