In a FSM article a few issues ago (Panther build), the builder used lead foil/sheet to create new fenders & cargo boxes and make them appear battle damaged. My questions are:
What thickness of lead is commonly used? What tool(s) are used to cut the lead? Places to purchase lead sheet in the desired thickness (I know that Great Models carries three different thickness, starting at .008 & up).
I used to work at a recycle center. Lead foil from dental x-rays (about the size of a matchbook cover) were easy to come by. Copper sheet (like from the craft store) would come through, and all kinds of thin copper wire. I use a metal straight edge and a single edge razor blade to cut it. Usually on a peice of glass. Give your recycle (metals) center a try. Ya never know what they got untill you go there as stuff comes in and gets shipped out all the time. Theres usually something that modelers can use. Cheap too.
Kenny-hadn’t considered that…normally my brew comes in a bottle, but I guess I can make an exception for my modeling…[;)]
Visited my LHS today and found some brass shim stock, packaged in various thicknesses, in the model railroad section. Going to give that a try. If it works, I can probably inquire and order more.
Brass is also available in rolls of very thin, soft material that would work well for your uses. Even the thin brass sheets are a bit on the hard side, but the rolls are very soft and can be formed like foil.
