I’m not quibbling with any of the points made by Phil_H. I believe I noted that it’s self-evident that Tamiya must work very nicely with its own acrylic thinner as well as other mediums. Because of questions raised on previous threads I had a nice chat with the manager of a big Dick Blick store which caters to the art community but carries every type of paint this side of a local housing contractor - and carries a lot of airbrushing equipment to boot (hadn’t realized how widely used the tool was in fine arts as well as crafts.) Anyway, he said that there were formal definitions of paint based usually upon the type of emulsion. He also said that within these definitions there were wide variations in the way paints worked - and singled out acrylics in this regard. Thus if we call a paint acrylic it may or may not thin well with water; alcohol might be just what the doctor ordered or it may destroy it. More to the point, some acrylics are great for plastic models while others - despite offering splendid colors on other surfaces - don’t adhere. For the modeler, I think paint is what paint does. If an acrylic thins and cleans nicely with water three cheers. If an acrylic requires lacquer thinner and all of the ugly that comes with it, that’s another story. As far as Tamiya goes, how well would it work with water alone? Life Color and Vallejo, as I understand it, will work well. I believe Badger railroad acrylics require water. I have no idea how well those two would do with lacquer thinner. However, I know Tamiya takes to it like a champ. I think we can see the other end of the extreme with Gunze Mr. Color. I never used the old “Mr Hobby” but understand they were acrylics in word and deed. The newer Mr. Color brand has acrylic on the bottle - but you don’t treat them like like some other brand. Below is a note sent to me by the manager of Hobbywave, a site that specializes in fantasy models, and pumps Mr. Color as top gun. (Full disclosure - I’ve used Mr. Color once and was extremely impressed with the lovely color and tough finish that resulted. The cost was using lacquer thinner as recommended and a respirator - a gadget that you very definitely want because Mr. Color is strong stuff.)
Dear Eric,
You can basically take it (Gunze Mr. Color - EB) as lacquer although more precisely they are solvent based acrylics. They are so far best IMHO if you minus the smell. Make sure you use good respirator.
You don’t want to thin it with water, you need to use lacquer/paint thinner or best to use Mr. Color Thinner.
If you’re not using Mr. Color Thinner, then test thinning with small mixture, if they get gummy then you can’t use it. (such as Tamiya thinner) If you’re going to use Mr. Color Thinner, try not to use Mr. Thinner for cleaning purpose, it gets expensive quick, instead use paint thinner, mineral spirits, etc from home hardware box stores.
Mr. Retarder is to slow the drying time, this is usually used for gloss effect, self leveling effect and some hand brush applying lacquer among other uses. If you’re just starting up, I’d keep retarder until you find specific needs.
Thinning ratio is usually personal preference though there are general guidelines. It will vary with airbrushing distance, effects you’re looking after, temp/hum etc. Try from 2:1 (thinner/paint), test on scrap, if it runs reduce thinner by adding more color, if it sprays spider web or if surface looks sandy or look too dry add thinner. If you’re particular about math, you can write all this down when you’re trying and then figure some specific ratio or if you’re like me mix whatever test and remix. Once thinned, store paint closed when you airbrush as thinner evaporates quickly, if you put much in the spray gun and spray long time (10-20m), it might dry up in the airbrush cup and you may need to add bit more thinner as you go, always sneak up on the adding/mixing with small amount.
If you have any other questions, please don’t hesitate to contact me, and good luck!
Thanks,
Sean
