Can I spray lacquer paint or clear coats over dried water based acrylics? I generally use Mission Model, Vallejo and Tamiya XF paints.
Thanks.
Thanks.
I found this to be a useful diagram to save
I do that on a regular basis with no issues. As long as you don’t go too wet and heavy with the lacquer you’re spraying, you should be fine.
I agree. The first coat of lacquer needs to be VERY light to avoid burning into the acrylic. Each subsequent coat can be a little heavier as you build it up.
Cool. I apreciate the feedback!
