Here, then is the latest kitbash. A Revell AH-64 Apache Helicopter kit, kitbashed to a Ground Support Fighter, armed with a rear facing rapid fire blaster, and two Sub Atomic Disrupter Cannons. Left side view:
Front view, with gunner standing:
right side:
Right rear quarter:
This last, a size comparison between the ground support fighter, and the heavy fighter/bomber
The large sphere aft of the cockpit, is the focussed translocator reactor, a matter/matter device that produces power by causing two equal masses to exist at the same point, at the same time. The reactor’s lining absorbs, and converts the energy released, to a usable form.
The main engines, and the roll, pitch, and yaw engines, are all inertial, there is no “emissions”, or exhaust. The small roll engines can be seen on the “wings”, extending above and below. The Pitch and Yaw engines are within the fuselage, the mains aft of the reactor, on each side. Computer controlled, the roll,pitch, yaw, and main engines, can lift the vehicle, in any attitude, in any gravity tolerable to humans. The vehicle is capable of vertical liftoff, nose down/tail up flight, and rotation through 360 degrees horizontal, and vertical, simultaneously, as the main, and other engines can each provide thrust in opposite directions along their axis.
