GM thank you these 1/72 multi engine planes are large next is a B24 in 1/72 another big plane tiny work space
Thanks Nick. Sometimes i put the tape on the canopy and using a #2 pencil to rub the frame outlines on the tape which I can cut with an Xacto. If not I use the thin tape to mask each panel which is a PITA. Thank God for the commercially available masks that save a ton of time and aggrevation.
The Dora’s mottling was done with a Neo gravity fed, extra thinned paint about 12 PSI. The nose spots are RLM84 Vallejo Air extra thinned and flow improver added, sprayed at about 30 PSI. Any lower PSI would give too much overspray. I went back with MM enamel RLM83 to kill some of the Vallejo overspray and to get a tighter demarcation line.
The splinter on your Ju52 kicks a$$. [B]
Looks great to me! Fine job, as others have said, on the paint and weathering.
