My current project is the Johan Mercedes 500K Roadster. But I am building it as a hotrod. HAHA
I have screwed up along the way, so in the pcs you will see the color the kit was molded in change from maroon to green. I had to combine two kits to build this.
On with some pics…
Here is the kit.
First, the chrome is a little on the bright, fake, toy side. So I stripped the chrome off some of the parts using LA’s Totally Awesome.
The first thing I did to the car parts, physically is I cut the fenders off.
Here is the floor pan with the front and rear fenders, and running boards cut off. This is the rough cut, I left some material so I can sand the part to the right shape.
Once I cut away half of the car, I got to work on the engine.
I kept the supercharged inline 8, but I hot rodded it. I added wiring. I replaced the chrome mesh air cleaner on the end of the intake with a “scoop.” And I replaced the end of the plastic oil filler with a wire dipstick handle to add a little detail.
Then the most notable hot rod feature. I replaced the exhaust manifold with 8 straight pipes. All the chrome in the photos below is done with SMS Hyperchrome. I love this stuff.
And then here is a shot of the engine sitting in the chassis with the body on it.
Exterior paint is applied now. I decided to try out Mission Models Paints this time. I usually use Splash Paints on my exteriors.
Mission Models Paints took a little learning, but I really like how well they coat. I screwed up the paint the first time by not following instructions. I just said this is acrylic paint, so I thinned it 50:50 with water, just like I do with Tamiya paints.
I tested the paint and it took a miilion coats to get and even color coat. I counted, it took 1,000,000 coats.
This couldn’t be right, so I looked up how I was supposed to mix it. 10 parts paint, 1 part poly clear, and 1 part thinner is what Mission Models said to use. I found this to be too thick, so I played with it and eventually ended up happy with 10:3:3 Paint:poly clear:thinner.
With the 10:3:3 mix, this maroon paint went over black primer and coated well with only 2 coats.
Once pait was applied, I added clear. I used my go to, my favorite clear… Mr Super Clear UV Cut from Mr Hobby. I have an airbrush, I can use any clearcoat I want. But I use this Mr Hobby gloss clear in spray cans. It is that good.
I made a little more progress. I have a rooling chassis!
I need to go back and make a driveshaft though. Johan didn’t seem to feel that it was important that the transmission and rear differential were connected.
The frame is painted the same maroon color as the body. And the wheels and tires come from Revells new 29 Model A kit. I painted the wheels BBS Gold.
The body is all done, and the interior is done as well. I just have to glue them to the chassis. After that I have to figure out the headlights and other fiddly little bits.
