I over weathered this model trying all the techniques on chipping, applying streak, rust, foam, heavy chipping, just to see what they look like, i don’t like the track came out too rusty/red but only sixth model. So tips are always appreciated
Looks great you’ll keep learning and improving with every build. Only see two things, in the last photo the tracks seem to be to tight it might need another link and the cross by the back hatch is not straight. Camo looks good.
Neat! Always good to try new things and experiment till you find techniques that work for you.
BTW: Are those rubber band type tracks? If you drill a small hole in the hull side where you want the tracks and then stick clipped pieces of a paper clip in there to hold them down you can get a decent sag effect. Not as good as multi-part tracks but it looks good from three feet/ a meter.
Nice Jagdpanther; though I will echo the two previous posts. Nice chipping effect, although it seems like a lot, so I’m thinking this is near the end of the war with the “Ambush camo scheme” and this Jagd has been hiding in some thick brush. Still a very nice job.
