Iwata Smart Jet Compressor Review
I have added a review of the Smart Jet compressor to my site. Comments and suggestions are welcome.
Thanks,
Don
You should have told Gary Glass that an Iwata Powerjet Pro would work much better in your setup. [;)]
As always, a very informative and unbiased review.
Thanks, Kei.
Honestly, I didn’t even know it was coming, and it’s perfect for me.
Don
Interesting read as always Don!
As far as a can see virtually all airbrushing oil-free compressors now use this piston & seal assembly as per the patent diagram - the only noticeable difference is that the piston seals are now somewhat heavier than that in the diagram.
Curiosity got the better of me a while ago, so I stripped my own compressor to see what made it tick - I was expecting to find something more like an internal combustion type piston swiveling on the connecting rod by a pin & using flexible seals rather than rigid rings - so was quite surprised to find a shallow piston tilting in the bore;
The extent of the tilt / wobble is slightly exaggerated in this image as the cylinder sleeve has been removed for a better view of the piston - the short stroke of the piston results in less tilt than you would imagine.
Thanks for the comment. That’s a great picture. It’s neat to see what one really looks like.
Don
The Iwata Smartjet compressor is one of their best seller, and not positioned as a low cost item. I never understand the logic of Iwata leaving out a true pressure regulator and substitute it with a bleed valve only.
From Don’s review, a regulator add-on works very well. A Sparmax pressure regulator costs £31 in retail in England. It should not cost Iwata more than 1/4 of that to add the regulator to Smartjet. But…
It’s a marketing decision, Kei. All companies have to make them.
I suspect I’m not the only one to add a regulator to a Smart Jet.
Don
