Iwata Silver Jet surprise
I got a real surprise with my Iwata compressor yesterday. I decided to have two airbrushs (one SA, one DA) online all the time. So I had to add a T fitting to the output. Now, the compressor came with an adapter to convert some odd thread to the standard 1/4 pipe thread. When I hooked up the original brush I did wrap the 1/4 inch thread with teflon tape before putting on the airbrush hose and its 1/4 to hose fitting adapter. I did not, at the time, remove that weird adapter and apply teflon- I assumed it would be a pretty tight fit from the factory.
I liked the quietness of the compressor but was a little put off by the fact that I could get no more than 15 psi when spraying. At times, especially for flats, I like to go up to 20 psi. But, I got along with it okay for about nine months.
Yesterday when I was putting on that T-fitting and nipples, and doing a lot of tape wrapping, I decided to remove that original adapter and wrap the thread on the compressor output. When I got all the fittings complete and both airbrush hoses connected, I tried out both brushes. I suddenly had 30 psi with the air flowing! Apparently I had leakage at that original output, but not enough to hear it. But it was apparently enough to lower the pressure! Now, I have two brushes online, a silent compressor (well, nearly so) and can get both brushes as high as 30 psi. I probably will never use them that high, but at least I can get the 20 psi when I want it! So wrap ALL the fittings!
Nice find Don. I have the Smart Jet and its ok for 1 airbrush, but it is tankless so any adjustment of the regulator keeps it running constantly even when your not pushing the trigger down on the airbrush. Does the silver jet have a tank?
I love my SmartJet. It can sustain 30 psi, but I usually AB at 20 psi or less. It is my understanding that the auto shutoff works only when you run the compressor at its full psi, whether it’s Iwata or other brands. To turn on and off my SmartJet, I bought a foot pedal on/off switch for like $15.
Chris, I do like the Smart Jet. I just hate the spitting noise of air coming out the regulator constantly when you turn it down and mine will get hot after long a/b sessions, cause its still running even when I pause momentarily with the airbrush. I rarely airbrush with it running at full psi. I’ve seen people plum a small portable air tank to it so it doesn’t have to run all the time.
Because the fan noise of my spray booth overpowers any noise made by my SmartJet, I don’t even hear the spitting noise :slight_smile:
I also have a small fan pointing to my SmartJet (bought one for $5 or so at Wal-Mart). Both the fan and the SJ are connected to my foot switch, so when I activate the SJ, the fan is turned on, too. My SJ never gets hot.
No, my compressor has no tank- runs all the time, and there is a big drop in pressure when I press the air trigger. I have to set the regulator with air flow. At least now I can control the pressure over the useful range I want to spray at. Great stuff that teflon tape!
The surprise is really not a surprise. It is true that the Iwata Silver Jet is rated only for 18 psi and 9 lpm (0.33 CFM) which are very conservative spec. Its maternal twin, the Sparmax AC-27, is rated at 45 psi. It can be had for $114 at Hobby Lobby with the 40% coupon.
I suspect that both spec are accurate. The 18 psi is at the max 0.33 CFM flow rate. The 45 psi is at the no flow condition.
Make no mistake, at 0.33 CFM, it is a very low power compressor and good for gravity feed airbrush only. But it has everything for modeling that a beginner may need for a very reasonable price at Hobby Lobby, with the Sparmax/Iwata quality as a bonus. It is not a compressor for serious modeler, but if you are starting out and have less than $120 for the compressor, this compressor is worth a look at Hobby Lobby.
For a little more, the Sparmax TC-2000 is a much better deal. It is steady at 45 psi when the total flow is 1.2 CFM. You may not need it most of the time, but it sure makes it easy to reset the airbrush pressure. I perfer the compressor pressure reading to be steady when I pull the airbrush trigger. The setting is more repeatable in all conditions.
I am using it on a Badger 200 and a 150, both suction/bottle feed, on the Silver Jet, and it works fine. Now, I almost never use either “wide open.” I consider an airbrush a brushmark-less brush, not a spray gun. So I am normally using either brush at considerably less than its maximum flow rate.
I use the 150 only for camouflage top coats or very fine lines, again, not stressing flow rate.
