Iwata hp-cs low airflow/ sputtering problem. HELP!
I recently started having issues with low airflow on my Iwata hp-cs. I’ve soaked the nozzles in solvent to get rid of any possible clogs due to paint and I thoroughly clean my brush after every use. So back to the airflow, the brush is very anemic when I try to spray air out of it. When I put water in it, there is an obvious sputter but I know it’s not the compressor (I have two compressors and several guns and it only sputters with the hpcs). When you loosen the nozzle and the nozzle tip a little the airflow increases. Anybody got a clue what’s wrong?
How’s the airflow with the brush “naked”?
Had something like this happen with my H&S Evolution, and it wasn’t about the nozzle being cleaned so much as the nozzle’s exterior and the nozzle cap. Weird I know, but it worked.
I’m not familiar with the Iwata HP-CS and its nozzle and nozzle cap. However, air doesn’t flow through the nozzle - only paint. If you loosen the nozzle cap and air flows then the nozzle cap opening is being blocked (screwing nozzle cap in too far?). Is there an O-ring behind the nozzle cap and is it missing? Or is it a ‘rubber’ one that’s getting old. The nozzle cap has a hole in which the nozzle must center and yet leave space around the nozzle for air to flow - if that space is restricted airflow will decrease. Alternately, have you made sure the nozzle is inserted (screwed or pushed - don’t know the CS) firmly. Not having the nozzle properly seated could also cause the problem by reducing the space between it and the nozzle cap. Hope this makes sense and that it helps.
The nose of the gun has four parts. Nozzle that the needle goes through, head cap screws on and keeps the nozzle centered and in place, a nozzle cap to go on top of that to focus the air out of one hole (the head cap has three air holes which redirects into the nozzle cap) and then a needle cap screws on top of that to focus both the paint and the air. There is an o ring between the gun and head cap. That doesn’t seem to be a problem because the airflow seems to be restricted by the nozzle cap because when loosened the airflow increases.
Oh and what do you think is causing sputtering?
On the CS and other internal mix airbrush, air comes out between the paint nozzle and nozzle crown. An inproperly seated/dirty crown or broken paint nozzle can cause the air to sputter. The CS nozzle is a self-centered design which could cause sputter is NOT seated properly. How well the inner nozzle centered when you look down the airbrush from the front?
From your discription, you are not talking about paint spatters which is usually the result of damaged needle and/or nozzle.
An online resource for trouble shooting.
If everything else fail, call Iwata service. Good luck.
I’m assuming that you get proper airflow without nozzle or nozzle cap in place. If so, then there is a restriction between the nozzle and the nozzle cap somewhere. Remove the needle cap (doesn’t affect airflow, only protects the needle) and look at the nozzle/nozzle cap from the front. There should be a gap between and around the nozzle and the hole in the nozzle cap - it might be small but must be there - it’s where air passes over the nozzle to ‘suck’ paint out. If there is a gap then you might have dried paint inside the nozzle cap since if you loosen it airflow increases. If there is no gap then the nozzle isn’t seated properly - something is causing it to protrude to far into the nozzle cap. Check the fit of the nozzle into the head cap - any paint, roughness or whatever. HTH but hard to diagnose without looking at the AB so If none of the above, Iwata service will help.
