The final scene will be (hopefully) close to the box art with added explosions and chaos for effect. Well, that’s the idea anyway.
I’ll attempt to make the crew using these kits, which will probably require some customising for hand positions particularly. The field gun I’ve had lying around since the 80’s, waiting to come in handy for something.
Are you planning on a European scenario? The reason that I am asking is because the figures are not exactly dressed for a tropical clime and I don’t think the USN had access to British 25 pounders in the Solomon Islands.
Actually the Pacific theatre. I should have mentioned, I’m using the basic torsos from the Tamiya 25 pounder kit as a basis for making JFK and the crew. I was watching a doco on these boats, and they were right down the navy food chain, so no neat uniforms or anything.
In the Mediterranean there were modifications to the the PT boats because of certain factors. Torpedoes were started and slid off the side. I believe because of closer ranged the blank round flash could be seen from tube launches. The 37mm anti-tank gun found its way on to many PT boats in all theaters. The USMC had lots of them, so did the Army. The gun would get damaged but could still fire. The issue was not a problem on the PT boat because it was in a fixed position. It had more “umph” than the 20mm cannon. The AP round could actually damage many of the enemy light units they came up against. I read an article about this once, I don’t have a copy if I remember I’ll look it up.
