Italeri 1/48 V-22 Osprey WIP
My build so far of this kit.
Pros: good subject, reasonable cargo bay detail, nice decals
Cons: Go buy two sets of files and a bushel of Gunze. Fit is craptastical
Cockpit: weathered a little, didnt put too much into it seeing as it wont be all that visable. Paints used were x-1 Black for bulkheads, Tamiya Light Grey for seats, belts done in Guardian Red, LED Green is from Vallejo. Silver pencil for scuff marks and pedals.
Troop Area:
Walkway in Tamiya Light Grey and NATO Black. Sidewalls Vallejo Olive Drab. I saw this with a cargo net at the Oceana Air Show last year. The net was constructed with tamiya tape cut into 1.5 in strips, primed and painted with Testors Guardian Red. Sidewalls detailed with silver pencil.
Gear Bays:
Polly scale reefer white. I preshaded the wiring in the nose gear and I liked the effect. Weathered a little with Doc o’Briens grime pastels mixed with a bit of thinner.
Dry fit looks promising.
More to come at some point. Critique is welcome!
Thanks!
I am gonna be watcching this build with interest. Just wondering if red is the correct color for the seat harnesses for the pilots though. I know next to nothing about the Osprey having never seen a real one with my own eyes. Looks like a big build in 1/48.
I have one of these, someone else built one on here, earlier this year or last year. Looks good so far. Im not touching mine till I have nothing else in progress.
Some Updates:
First off thanks to MedicMan for his great build especially with the flaps!
Also, this is my first foray into scratchbuilding and I suck at it.
I also have noted that every pic of a parked Osprey has flaps at 90 deg.
I cut off the flaps with a bone saw and sanded them flat. Then I used some leftover sprue to brace the wings so they don’t flatten at the medial apices. Plasticard covered the openings and Milliput was used to fill the flaps. Unlike others, i did not cut the flaps into four pieces. Baby steps. Fuselage sealed with Tenax.
Tape is my attempt to not mess up surface detail while sanding. Alot. I mean a ton of sanding. Still needs more. this model is begging for some Mr Surfacer.
Thanks for input.
More progress:
Masktastic. Canopy dipped in Future then Eduard.
Seam lines are very prominent:
First application layers of Mr. Surfacer 500. Getting a little better, much more surfacing and sanding to go!
Very nice work. I’ll be following your progress with interest.[Y] Heck, It might even give me the motivation to bring mine out of mothballs.
This looks great… I love watching someone taking a basic kit and turn it into something amazing. I cant wait to see it finished
We moved, hence the lack of uploads:
At the suggestion of a forum member, I used sheet aluminum to recreate flap cowlings
Primed up and pre shaded!
Basecoat on. Testors Light and Dark Ghost Gray Used:
Masked out the cowlings and leading edges (Testors metallizer Burnt Metal and Tamiya X-1 Black):
Final coat after light sanding with 12000 grit micro mesh:
Turboprops: Dark Ghost Gray, XF-1 Flat Black, Drybrushing done with a 50/50 mix of Titanium Silver and NATO Black. Intakes airbrushed with Alclad Duraluminum. Exhausts are made with screen door meshing.
More to come…thanks for comments!
David
Looks great. What are yoy using for your preshading and how are you applying it? This kit keeps staring me in the face at my LHS just dont know if its woth the price tag.
I used tamiya xf-1 black for preshading. You’re instincts are right. This kit can be a lot of work. The fits are fair but it’s no tamiya kit. Lots of sanding and resanding. But it’s not the worst thing in the world. Its a big one when it all comes together. Not sure where I’m gonna put it when I’m done.
D
Looks like its coming along VERY nicely…
Well it’s mostly done , although not very satisfied with the end result. I didn’t do well with the thick decals.
