HEY,
I was wondering, if i was just going to do body painting on cars, Would it be worth the extra money to get a duel action over a single action airbrush? I dont want to spend too much if im not going to need that extra control. Also, do i have to have a moisture trap? Does a filter do the same thing? Thanks for any answers.
If you are going to do single color or two-tone paint jobs, go with a single-action. The learning curve is much shorter and with practice, you can do just about everything a D/A can do. I have both types and use the D/A mainly for camo on military subjects. But do get an internal-mix single action. IMO they give a better finish than external-mix ab’s. And definately get a water trap and filter / regulator. Good luck!
But double actions isn’t that much more expensive than single action. Why not master double action now rather than learn single action and then learn double action? Maybe later you may need a double action for something new you like to try.
Try http://www.dixieart.com
It’s not common to find better prices than Ebay at dixieart. It happened to me. I’m sort of glad I lost the bid to this airbrush because I’ve found the samething on Dixieart that is 20 bucks cheaper than the winning bid on Ebay. Not to mention the thing from Dixieart is unopened and it comes with a braided hose which makes the deal sweeter.
I have a double action and it is rare that I utilize that feature when doing autos. I generally lock the paint flow and let-er-buck! There may be times when you’d utilize the double action, but my thinking is that would come into play more on complex camo schemes and various other types of free-hand painting.
I bought the double action so that I would have that feature whenever I did build some planes or other items. It does take a bit more time to get used to, but I’m glad I’ve got it.
That is pretty much true what you said. What I like about a double-action airbrush though is that after spraying a pass or two across the model you can keep the trigger pressed after the pass and spray just air out of the airbrush which helps cut down on tip dry and keeps that drop of paint that stays on the end of the needle away. Have you ever sprayed a pass and then forgot to turn the paint on before getting to the model and got that drop on the finish? I hate that. lol [:(]
