Magic Factory announced a first plastic model in the company’s portfolio, featuring air defense system “Iron Dome”. Check out the company’s press release and promo images!
Air Defense System “Iron Dome” Kit Coming Soon!
Magic Factory 1:35 plastic model kit Air Defense System “Iron Dome” will be released soon! This is our first fine and precise plastic model kit, no. 2001.
The model needs cement for assembly. It can be built in combat state or transportation state, and provides missiles for separate display.
Besides the injected sprues, the kit also includes a PE set, metal parts, a multi-in-one film-free decal and a common decal. Each PE part is made singly, which is isolated from the PE tree. You can pick them directly for use simply by a pair of tweezers without cutting and polishing. The Multi-in-one film-free decal will help you apply multi markings to the model by one time. You will not worry about markings not well aligned.
The model is a precise replica in size and appearance, with a length of 199.5mm and height of 241.6mm after assembly. There are parts and painting schemes available for options to build Israeli or U.S. version system. By rational part separating and appropriate ingredient of material, the kit is fine in details, quality and interesting in assembly. More product details will be released later.
To follow us for more details updates, you can like us on facebook by:
https://www.facebook.com/Magic-Factory-魔力工厂-109212901305235/
