Interior Fotos of Me 109
Does anyone know where I can get some interior fotos?I am not interested in buying a book since I am doing only one palne of this type.
Try www.luftarchiv.de.
There are cockpit shots of most Luftwaffe aircraft on the site.
Use the English navigation, unless of couse du kanst Deutsche sprechen!
Karl
I got a lot of my info from
http://s96920072.onlinehome.us/AWA1/301-400/walk365_Me109_%20G-2/walk365.htm
Also see
http://s96920072.onlinehome.us/AWA1/001-100/walk037_Me-109_G-10/walk037.htm
Hope this helps.
There also a couple of site dedicated to the BF 109’s.
http://www.bf109.com
Try here
http://109lair.hobbyvista.com/i
question what type of 109. or should i say variation. as i learned recently there are many variations. (i learned something, thanks blackwolf)
joe
NP, Joe…
Here’s some links which will definately help you out, Greg:
The 109 Lair - This is one of the better 109 sites on the net, but it’s finicky to navigate sometimes. There’s alot to see here, including some good cockpit photos.
Bf 109G-2/trop W.Nr. 10639 - Otherwise known as ‘Black 6’. This is a page from the 109 Lair, and is the most complete cockpit coverage you’ll find on that site; if you’re building a G-2 then this is for you.
Bf 109G-6 at Central Finland Aviation Museum - If you’re building a Finnish bird, this will help you out.
If you don’t see anything that will help you here, then give a shout. I may be able to help you out further…
Fade to Black…
