Short answer is, you can get a really good finish with just paint but you have to learn how to reduce it and spray it. It can be done. Light coats first for some coverage and then heavier wet coats. Once you get full coverage with a wet coat, let it set for a little while, reduce your paint a little more and do it again. Hate to say it but you’re going to have to suffer through orange peel and runs and sags and any number of other problems until you get the hang of it. That’s just the way it is.
Getting that showroom fresh and smooth paint on a car requires removing any orange peel you have in your paint. It is rare when you can lay down a finish with no peel in it. So wet sanding is to flatten those areas out only, not to make it shine. The shine comes from the finest of the pads making that surface glass smooth. Then when you are there the polishes like Novus are to bring out that shine in the super smooth paint/clear. And no you wont get any blotchiness in the finished product if you take your time and slowly work the paint smooth and then polish it. You can’t really see the OP in the body lines or sharp edges and when its done the super smooth and shiny paint forces the eye to see that and not any small OP in the edges, which likely aren’t there any way due to how the paint will flow away from those edges when you spray and it settles in.
Again, wet sanding is not done in 30 mins. You should take a least a few hours to carefully work the paint out grit by grit till its perfect. This is why 1:1 cars cost so much to get a super nice paint job. It’s all the labor in sanding down the coats and clears to make it perfect and then they polish it to get the shine. Sanding only gives you the base for the polish to achieve the shine.
You definitely have to have good body work in order to get a good paint finish. Kind of like building a house, if you don’t get the foundation just right everything that follows will be off as well. Now, the color you decide to paint the vehicle can also make a big difference. There’s even a saying in the auto body industry, If it ain’t right, paint it white. Black and silver are probably the hardest colors to get a perfect paint job with.
That’s why I build mostly tanks and fighters. No gloss finishes, except when I apply decals. No big seam filling. Flat finnishing. I’ve done one car for a friend, 20 years ago, that’s it for me. I had one little cat hair that landed on the finish, and after much wet sanding with extra, extra sanding I got the plastic kit looking good. My buddy just put it on the back shelf of a case, and that was that. I’m back to tanks.
That’s very true, tankboy. If you don’t like what you are doing you won’t find youself doing it for long. In the end if you don’t enjoy the work to get that perfect finish you probably won’t be building cars for too long.
The orange peel on my finishes are VERY light and are removed by the Novus as the paint can be seen on the t shirt after polishing an area. It takes time and patience to rub the paint out, each time changing sections on the t shirt to keep a clean polishing cloth. The only times I wet sand is if an area is very grainy or rough. It takes several coats to build up the paint thickness so some of it can be removed during the polishing step.
True that. Armor Is great to work with specially easy to hide gaps and steps with pigments and weathering. Just throw some mud on that ugly gap and problem solved. [;)]
It’s not like the effort is really difficult, it is the subject. I just don’t care for cars, real or models. I just see them as ways to get from point A to B somewhat quicker. Car models are fun builds and I admire the artists who do them. Now that said, I’m building now an ESCI 1/9 scale Kubelwagen. Go figure. I just finished a old kit 1/35 of a DML Pzkfw III ausf G. I’ve done it Panzer grey.
What Brandon meant was that you don’t want to sand the peak where the surfaces of the body panel come together. That peak has the least amount of paint on it and you will sand (burn) through the paint a lot quicker than the flats of the panels. It’s a thin enough line that your brain will trick itself into not seeing a difference in the shine. As others have said a smooth foundation makes a smooth paint job that much easier. Sand the body smooth to get rid of the mold separation lines. Sand the primer smooth. Apply the color coats. My base usually consists of 4-6 mist coats to get full coverage with about a 10-15 minute wait between each coat (shot from about 12-18 inches away from the body). Then a couple of medium wet coats shot from about 10-12 inches away from the body, usually about 15-20 minutes between coats. Then a couple of wet coats shot from about 8-10 inches away from the body, with about 20-30 minutes between coats. I rarely use a clear coat because the cars I tend to build never had them. I then set the body aside for a week or two to let the paint cure. This is using Tamiya spray lacquers from the can. In the old days of using enamels, a body could take 30 days to properly cure. Make sure you paint the hood with the body, especially if you’re painting it white (ask me how I know this). Also look for any molded in underbody reinforcements or places that have been thinned out so you can cut a hole in it (usually the hood). These can create a slight depression which you may not catch until you’ve shot your body color and they create a ghost image in the paint. They can be found by sanding the body before you primer it (the low areas wil still be shiny so sand until they are gone). If the bonnet or boot is removable, pay attention to the edges. The molds, depending on how much use they’ve received, may have a slight curve at the edges resulting in a peak being formed that you may not find until you’ve burned through the color coat there. Sanding the parts before painting should catch this. I never wet sanded a body, only dry sanded. I would cut the sand paper into small strips about a 1/2-3/4 of an inch wide and maybe a couple inches long and would get maybe a panel out of a strip before having to cut a new one. Regardless, watch your sand paper. If the grit is starting to get clogged, either rinse it out or get a new piece. As others have said, it takes at least a couple of hours to properly and carefully rub out a paint job. And as with everything, practice, practice, practice.
Thank you so much. I feel like this is a post I’ll be referring to years from now. [:)]
When you speak about mist coats/medium wet coats/wet coats, are you only changing the distance of the airbrush from the body, or are you also changing the dilution of the paint with the thinner?
I primarily use Tamiya rattle cans, so I don’t worry about paint composition. The distances are for spray cans, but can be adapted to airbrushes. You’d just have to experiment and find the distances for your airbrush. I use distance to control the amount of paint that goes on the model.
lewbud’s method is spot on. Now it’s just a matter of getting used to doing that with your airbrush. My apologies, I got frustrated with these pop up ads the other day and didn’t go into detail. I would sometimes thin color coats more as I went along but not always and only with solid colors. You don’t want to do that with metallics. I did always do it with clear. But, I was also using lacquers almost exclusively. And normally used clear fingernail polish for my clear coats. It’s a tough, hard finish that doesn’t yellow, sprays very well and was readily available. There are a lot more products on the market today than 10 year ago but, at least in the US, almost any drugstore, supermarket or retail store sells fingernail polish. You can get some pretty nice colors too. Just thin it with lacquer thinner. I have seen some people say they used a fingernail polish that didn’t work with lacquer thinner but it never happened to me.
You definitely need to thin your Tamiya paints. Try to use 15-20 psi for air pressure. A little more if you need it. Remember you’re using an airbrush and not an aerosol. You have much more control. You can slow down and get closer. BUT, you’re painting a car body so you’re still going to need to put out some paint. Light mist coats are what you start with but you need to progress to wet coats. That’s what allows the paint to flow and level out. Too dry or too thick and it won’t. Too thin or too heavy and it will run or sag. It’s something you just have to do and get experience with. It takes time. Don’t get discouraged. You can do it!
Another biggie to keep in mind when spraying with a can or AB is to always start before your subject and end your pass after the subject and keep it moving. Don’t change directions while on the subject either. This is especially true of colors that contain flake or camillian affects. And like Lewbud stated, try to paint with all the parts in place as it will have an affect in the look when it’s done. Your best to start off with a kit or two that you are not super stoked about so you can afford to make mistakes and experiment some. Then when you get a feel for what you’re doing you can then transition to a kit you really want to look good.
All the stuff everyone has mentioned here applies to this hobby. Above all, practice and patience is key. Good luck.
I tried your suggestion first because it was the easiest and I’m pretty happy, surprised and impressed with the results! All you do is rub the course compound with a “not-too-smooth” cloth and you can actually see (and feel) the orange peel fade away. I should’ve taken a pic of the model before I started to show you what it looked like with the orange peel. This is a huge difference.
One question though: what do you do with the compound that gets in the nooks and crannies? Some places are too small for even a q-tip.
Here’s the body after the course/fine/wax applications. This is pretty good compared to what I’ve done before. It’s not as good from all angles (I am using some photo-trickery), but for the easiness of the method, I can’t fault the payoff.
Without sounding ungrateful and full of self-pity, it’s still a long way off the manufacturer’s results.
Sometimes I wonder though about the official pics. Look at this tiny sign on the side of the body. On the manufacturer’s pic, you can clearly read it as Hertz. I’ve taken a pic of what I got in the box. Couldn’t get a closer pic with my phone but it’s pretty close to what you see. There’s a big difference. Do these pro modelers use a pin or something to etch out the words again? Or maybe print a sticker to go on top of it? Puzzling.
