WIP BLOG and Finish photos are here: https://imgur.com/a/2GfFk
This is ICM kit # 35081 Made in the Ukraine in 1/35 scale.
This will be an OOB build that I’ll try to slam out by the end of January.
I started the kit on the local pier while fishing with friends.
This lower hull part was warped so I submerged it into hot (not boiling) water for one minute then tweaked it straight again once I got back home.
All of the parts in this kit had an incredible amount of sticky, greasy mold release agent used during manufacturing. I didn’t get pictures of this in my kit but you can see examples of this shiny grody substance pictured by Ray Mehlberger here:
http://www.cybermodeler.com/hobby/kits/aer/images/aer_t-28_parts05.jpg
http://www.cybermodeler.com/hobby/kits/aer/images/aer_t-28_parts08.jpg
I tried soaking and scrubbing in warm soapy water but it did not dissolve this substance.
I had to use a solvent, Denatured Alcohol.
Each sprue was dunked then agitated vigerously for about a minute each. Then layed onto paper towel to air dry.
