Hello, im new to modeling, and i just finished painting my first model, a 1970 Chevelle SS454. Te problem is that i got plenty of orange peel[xx(], and i want to know how to remove it once the paint dries. The finest grit sandpaper i have is 1500, and i cant get anything finer in my area. Any help would be greatly appreciated[:D]!
Welcome to the forum and the hobby. The only answer I know of if it is very bad is stripping it and trying it again. But then I have always had bad luck with orang peel myself. Hopefully someone else will have a better solution.
I checked all the auto and hardware stores today, and i couldnt find anything finer than 1500[|(] !! Can i still get a good finish with 1500 grit, or am i screwed?
[sigh]
Thanks for all of the replies guys, keep sendin em in! [bow]
You can use the white sheet and the red sheet of sand paper in theTestors model car sandpaper pack from any hobby shop,or Wal-Mart.Plus,it’s cheaper than auto sandpaper.
You can still get pretty good shine without a full polishing kit. I’d suggest wet-sanding up to the 1500 grit (watch the corners and edges very carefully though - actually, I’d suggest putting a thin strip of masking tape over all of the edges/corners to prevent sanding through the paint.) Then, you could use some paste-type polishing compound (not wax) on it. Tamiya sells some, or you might try some of the automotive stuff (Turtle Wax brand, 3M brand, etc… check the automotive section of Walmart)
After that, you may want to shoot it with clear coat for a final ‘shine’…
Yeah put away the misery! Just strip the paint! And try again, again, and again till you are satisfied! Trust me. Later on when you got the feel, and when your paint jobs look good. You will appreciate it most!
The other option is to remove everything by stripping the paint completely. In the UK, there is a product called Mr. Muscle Oven Cleaner. Although not designed for models, it will completely strip off paint, varnish, decals - the lot - without damaging the plastic. Apply it to the model, seal the model in a plastic bag and let the chemicals do their work. After a few hours, take the model out - wear gloves - and wash it under running water. The whole lot should rinse away leaving an undamaged plastic model.
I would suggest trying it out on something old first, but I have heard it works extremely well.
Hope this helps.
shalin,
when you say you checked ‘auto stores’ do you mean like autozone & pep boys?
what you really need is a bodyshop or a place that supplies bodyshops.
if you are in SoCal, there should be some around!
I regularly get 1500 and 2000 grit from a couple of my local hobby shops. And I’m in Phoenix! If you’re in SoCal, you should be able to find something, somewhere. Grab the Yellow Pages and let your finger do the walking!
