I need Tiger color help! I am guessing this topic has been flogged to flinders, but I can’t seem to find a definitive answer.
I am starting the 1/25 scale Tamiya Tiger, and have discovered that getting color info is horribly complicated.
First, I realize that the plastic in this kit is fraught with errors in dimension and details. I am fine with that… BUT, I really would like to get the colors right, specifically the interior.
I am reading that some early Tigers had a light, blue-grey interior from the sponsons down, with a light cream, or ivory for the remainder. I have also read that at some point that the portions below the sponsons were red-oxide primer, with everything above that in the cream/ivory color.
So, any help with this dilemma would be greatly appreciated.
Also, I will be using vallejo paints so any paint numbers would be great.
The Ivory color you are describing is called Elfenbein. There are a lot of links to the interior here:
http://www.militarymodelling.com/forums/postings.asp?th=96291&p=1
And remember that Museum restored examples are not accurate most of the time.
First off, Vallejo’s idea of red oxide primer is a set of 6 paints, allowing for shadows, highlights, mid-tones, “volumes”, (isn’t that something women do to their hair?) and whatever else they deemed necessary;
Funny, they only show 5 color swatches here…The fourth one looks close to being the base coat, so go with something like that if you don’t want to shell out for the whole set.
The green-grey you want would be Vallejo 972 (107) light green blue. This seems to be the overall choice from various opinions to be a good representation of RAL 7009 green-grey. (Sorry, no 6 paint color system here). It also appears to match preserved equipment in this color that I have personally seen.
Elfenbein… “ivory”…let’s go with Vallejo 918 (005)… Ivory.
And of course, black.
Now you get to figure out which color goes where and with what time period of construction. I lifted this general description from David Byrden’s article on panzer colors as a rough guide;
“In the lower interior of the tank, the grey-green covered just about everything. Transmission boxes and other modules, which were perhaps manufactured separately, were ordered to be delivered in grey-green. Torsion bars, levers, transmission shafts, floor panels (yes, top AND bottom surfaces) storage boxes, etc. were painted uniformly grey-green.
In late 1942, the manufacturers were ordered to stop using the grey-green paint, and leave the bottom of the tank in its original red primer. Wherever grey-green had been used, red would appear instead. This was definitely a step backwards in terms of ergonomics - the red paint was quite dark. However, Mr. Doyle has found plenty of surviving vehicles proving that this order was obeyed. Sometimes he finds a red lower area with a grey-green transmission box or turret motor, because such items were stockpiled for some time before use.
Within the upper, Ivory part of the interior, all items of what I would call “working machinery” were painted black. This includes MG mounts, movable handles, vision ports, gearboxes and handwheels, etc. Also, it seems that every equipment stowage point was labelled, by hand or later with decals. In both cases the writing was black and had no background.”
You are going to need photos to help you in your process, Google is your friend, unless you want to start throwing money down for some books. And I wouldn’t use the restored (or even the unrestored) Bovington Tiger as your Bible either…The blue-green they used during restoration is so very wrong. There are other problems as well, like the green breech on the unrestored vehicle.
I know you realize this kit is not exactly state of the art by any standard (cough, cough) and the interior leaves much to be desired. Here is some discussion about other’s efforts to bring her up to…well…some kind of standard;
Good luck!
Ixion, thanks for the detailed reply. Exactly the kind of info I am looking for.
As for the accuracy of the kit, I am going in knowing that for sure. I read something back in the '80s by Shepard Paine that points this out, and since getting back into the hobby a couple of years ago, I have read quite a bunch about it.
I am building the kit for two reasons: it is for a group build I am participating in; and as a way to practice both interior and exterior painting methods. I figured since it has a basic (very basic) interior it would be a good way to do that without spending an excess amount of time and money on a nicer kit, just to botch the paint.
Thanks again for the reply. It has been a huge help.
I tackled this kit about ten years ago and just “winged it”. I fabricated interior details as best I could using sheet styrene and balsa wood. Even though highly inaccurate, this model stayed on static display at the LHS for two years and got a lot of positive feedback.
It was just an absolute blast scratchbuilding interior details, even though…far from exact. From my research there are three primary colors involved Eifelbein, red primer and panzer gray.
Crockett, thanks for the reply and photos. That is a great looking kit.
As for winging it, I am reminded of Shepard Paine’s remarks in one of his books. His main concern was making the inside of a vehicle, or at least the parts that were visible look busy. Add whatever is on hand that looks reasonable to give the appearance of an interior. He called it “creative gizmology.”
Yeah, I was still maturing as a modeler when I did this. What I found was that dimensionally, the interior of this kit was designed to accomodate an electric motor and drive gear. There are limitations as to what you can do with this kit. Also, I used some high school math to calculate fabricated parts in 1/25th scale. All in all, a very satisfying project. As my skill level improved, I was a little embarrassed by it, but my peers have all been understanding…LOL
Later on, I went for the gusto, outfitting this Panther with a full TWorkshop resin interior:
