I think I vented on this very subject last year…but I still can’t get acrylic paint to work and it’s pissing me off!
I’m building a Jagdtiger. Since acrylic paints seem to be the future, I decided to use them on this model. I usually use enamels and have had no problems with them at all. I bought Vallejo primers, paints, thinners, and airbrush cleaners. I use a Iwata HP-B airbrush. My compressor has a moisture trap.
My problems: The paint dries very, very quickly on the airbrush tip, even when I use retarder. I can spray only 2-3 seconds before the tip clogs. I thin the paint before spraying too. After I clean the tip, I get a splat of paint when I start spraying again. So, then, I clean the tip, start spraying off the model to clear off any residual cleaner, then try to spray the model. But, the paint then dries and clogs the tip again almost instantly and I have to repeat the process again. I end up spraying more paint off the model to clear the tip than I actually spray on the model itself.
Because the paint dries so quickly, I have to do a complete tear-down of my airbrush to get it clean. If I don’t, dried and clogged paint gums up the needle action and it wont move back and forth like it should.
I’ve watched many videos about using acrylic paints and Vallejo paints in particular. They all say that I’ll have to clear the tip every now and then, but never as often as I have too.
Varying the air pressure doesn’t seem to do much to keep the tip from clogging.
So, what do you guys suggest? Also, how do you strip off all the acrylic paint off of a model? If it were enamel paint I’d just use oven cleaner. I’m thinking of starting over again on this model. I just may switch back to enamels, but I spent a lot of money on this acrylic crap…and I’d like to figure out how to use it.
Any help would be greatly appreciated. Thanks for letting me vent.
