Hummel and Mobelwagon Tracks
So I am nearing completion of these two models (both 1/35th) but would like to get either Fruil or Model Kasten tracks. Problem is I don’t know exactly which ones I would need. Both are based on a modified Panzer IV chassis. Any help would be greatly appreciated.
Chris
p.s. I’ve tried using the ones that came with the Hummel (Dragon) but they are driving me crazy because they won’t stay together. I’ve heard there are sets that have a piece of wire that is inserted to make the track workable. I believe this would actually be better for me. Thanks again.
your after Fruimodel tracks, there the ones with the the wire (but i use pins)
you should look for the ones with ice cleats (they maybe the late type)
How are you assembling the Dragon links? They aren’t meant to be workable and should fit heel to toe. I’ve built the Dragon Hummel and had no problems with them, used regular model cement and had more than enough time to fit them around the wheels as needed before they set up hard.
Be aware that replacement tracks will cost more than the kit and will require their own amount of special work to use, I’d hate for this to be a case of out of the frying pan an into the fire for you. Good luck either way with your build! [:D]
