Recently, I tried to correct a painting mishap after I had applied Future prior to decalling. I had been airbrushing both a Humbrol and an MM olive drab shade to appliy a mottle camo on a Me262. The Humrol color just would not “grab” the gloss surface no matter what I tried in paint thinning or air pressure or roughing up the suface. Frustrated I then tried the MM color and it “grabbed” the surface just fine. My conclusions, for which I would like to hear of any similar experience:
The MM paint seems to behave like a “semi-lacquor” - compared to Humbrol, it dries much quicker and gives more of a smooth semi gloss appearance. Humbrol matts seem to give a very gritty coarse finish and dry more slowly. For these reasons, I prefer MM if I can get the color that I am looking for and for the easy-to-open bottles. The Humbrol cans do have a tendancy to skin over once opened no matter how hard you try to clean and reseal the lid.
Have others found that MM seems to have some properties similar to lacquors? I do like using the Tamiya rattle cans for applying large area colors - the lacquor paint lays down beautifully for a smooth semi-gloss finish. i have also found Scalecoat paint [a lacquor base] to airbrush very well - unfortunately they specialize in railway rather than aircraft colors.
Did you stir your Humbrol paint thoroughly as opposed to shaking the bottle/tin? This could be one reason Humbrol is coming out gritty. I never shake any paint bottle whatsoever. It’s better to give it a nice stirring to loosen up any settling in the bottom. Both Humbrol and Testors Model Master are enamels - certainly Model Master are not lacquers in bottles.
I’m not sure if I understand this, but it sounds like you’re trying to put a coat of flat paint over a gloss coat (or Future) which could be one other reason why Humbrol isn’t “grabbing” too.
I know stik uses both Humbrol, Model Master, Tamiya, I know he never had issues airbrushing Humbrol paint.
I’m a long time Humbrol user and I like those paints. They have the advantage of being oil-based which makes them somewhat resistant to contamination of the surface to be painted, but also to contamination of airbrush air with compressor oil - of course within certain limits. Clean surface and clean air are always better. I also painted over future coats without problems. You can get into problems with dry, dusty coats that don’t stick when airbrushing, when you don’t thin the paint enough, when the air pressure is set too high or when it’s hot - and then the paint dries mid-air and hits the painted surface dry. It could also happen if you mix just the pigment with the solvent and the carrier oil stays in the can - when the paint isn’t mixed throughly. So these are the things to watch for.
As for the cans - I prefer them over the Testors bottles, because I can never seem to keep the threads clean and then I have a really hard time unscrewing the bottles. The cans are better here - a screwdriver always opens them no matter how dried-out they are. To keep the paints from drying in the container it’s important to watch for two things: First is preventing the solvent contamination - don’t let extra solvent get in the container. So dry the brushes carefully after cleaning, before dipping them in the can and never put the thinned paint back in the container where it is stored for a long time. Second thing is an easy fix - to put the cans or bottles lid-down. This way the paint seals the lid and the extra air can’t get in and nothing evaporates either. For years Humbrol even puts a sticker with the paint number on the can bottom to facilitate the lid-down storage.
I hope it helps - good luck with your builds and have a nice day
I primarily use Testors enamels (much easier to find than Humbrol in my area). I see little difference between Testors enamels and lacquers when working with flats, but a big difference between gloss enamels and lacquers!
BTW, I also have a bad habit of not wiping bottle threads clean enough with ANY brand in bottles, but I still prefer them to cans.
I have found Humbrol paints to be very good, even after storing them for 20+ years. They also brush out better than MM enamels. I think because they have a thicker pigment over MM.
Unfortunatly, I have not been able to locate any Humbrol paints locally so I have been using MM enamels which perform ok in the AB.
I have some MM enamels go bad after a year or two so I question their quality control.
Thank you all for your helpful comments. They say that you learn by your mistakes and I know what mine was in this case. I should have removed the Future with Windex and removed the offending painted area with a quick wipe of lacquor thinner. Then I could have started again with the airbrush. But having said this, I still think that the MM enamel is different to the Humbrol formular. In my case both the enamels were mixed well with a Badger stirrer prior to airbrushing. I use the Testors enamel thinner for all enamels - mixing in the airbrush cup with the Badger stirrer. I do use Humbrol a lot; it is just a preference for MM if the color I need is there.
I am a die hard Humbrol user. Once I got the stirred not shaken part figured out, they became my go to paint for enamels. I still have a couple of tins that are well over 20 years old and still usable. I am fortunate to get half that many years out of any Model Master paints. Especially more recent purchased batches. Humbrols hand brush better in my experience, and give better one coat coverage, as well as flatter finishes.
and at around $2 per tin vs nearly $4 per bottle at the LHS, my money goes a bit farther with Humbrols.
I have a little aluminum “slot” fastened to my workbench to hold the square Testors bottles when I turn the caps with pliers, but always have a heck of a time with the MM round bottles. I recently found that those rubber pads used to hold kitchen jars with reluctant lids work nicely on MM jars, so I liberated one of those pads from my wife.
