hello to all .
this huey , I realized it 3 years ago but I did not have time to share with you , given the current situation , I take advantage of it .
I would like to make this photo in part since I don’t have all the figurines but it will allow me to work more on the huey .
I will use this kit, plus the Eduard PE .
and then a small find, thanks to rotorman , the pilot helmets with the inside , it is in a verlinden kit for a cobra
photo of rotorman :
the Archer sheet to make the rivets inside the front doors , as explained rotorman on his medevac , the grid for the turbine filter .
for the beginning , there was a bit of drilling to remove some parts to improve and to remove any course since the 2 half-fuselages have an air inlet for the model B while I make a C .
here are the parts removed in blue:
the grid of DECAPOD will be used for the part in arc of circle which is the filter with particle which is at the foot of the rotor
A few small improvements on the doors with rotorwash photos of the real door :
those of the kit with 0.3 mm CP addition, then a light putty between the 2 parts then PE eduard:
I’m handing out more tomorrow, promised on something else from the huey.
phil .
regards .
