How would I go about maing a "candy cane" Range finding stick?
How would I go about making one of these. I belive they were used to find the range. I belive scouts used them.
You’re referring to aiming stakes. These weren’t used to discover ranges. Two would be set some distance behind the artillery piece. The aimer would use these to calculate azimuths for fire missions. AT guns would not normally be issued these as the firing calculations would be for indirect fire.
Paint your stakes white, then mask with tape, paint it red.
Thank you for the information sir. One more thing to add to the roof of my quad[:)]
Raventutor11;
Use thin gauge wire to make these. A straightened paperclip would work.
Cheers;
Gregory
Our 81 MM mortor pit crews would have these set out and checked every time the crews changed.
