I want to know where and how can I upload the pictures that I want to post… no problem with photos that i can find in the internet… but… what about my own photos?..
zeroenna , do you have your photos posted on the internet?
If not, you can try out www.photobucket.com or http://rongeorge.com/modules/Gallery/models
I am not familiar with photobucket.com but have used Ron’s site.
Login with the words below:
Username: newfsm
Password: models
Click on the upload picture and then where it says <> scroll down and hit the “add photos”
A pop up screen will appear and will browse your computer. Click on the pictures you want added and caption each picture with a short description. I think you are limited to 4 pictures of each model you want to display.
Once your photos are uploaded into Ron’s album, click on one to open it. Right click on it and click on properties.
Highlight the address ( example: http://rongeorge.com/albums/scifi/class1.jpg )and copy it.
Create a post on here and paste your image in between the brackets
[ img]…[/img ] ( except no spaces in the brackets … !)
It should look like this:
[ img]http://rongeorge.com/albums/scifi/class1.jpg[/img ]
I had to put spaces in the brackets so the lines above would print in this post. Once I remove them I get this:
Hope this helps some
Regards, Dan
Wow, Dan, that’s a long time that I’ve seen that spacefighter. Wasn’t that for a GB that was going on around the time that I joined (one year or so) ?
Anyway, I’m using Photobucket and it is very easy ; you just register for free and you can start uploading your pics immediately, you can also add sub-albums so that your pics are sorted per project or so.
An advantage of PB is that when your pics are uploaded you can see them with the code under them that you can copy, and then paste here in your reply to post them.
Ok… thank you a lot… I’ll try that…
