I had a question for everyone, if you would be able to help me out.
I’m trying to find a chart or some type of reference on model figures on models.
Example:
do you use a 1/72 figure set for a 1/72 bi-plane diorama without making the figures look like they are over powering the scene?
If you have a reference or a chart that I can use to match the size of the model to the figures to create a diorama. I would greatly appreciate it.
I’m currently working on a Fokker D VII from revell 1/72 kit Bi-place and I would like to create a scene with the ground crew helping the place take off.
Anytime I want to scale an object I just simply divide the full scale dimensions by the scale your in. Example: A 6ft man would be 1” tall in 72nd scale (72”/72nd scale= 1) In 1/48 it would be 1.5”. You can use this for anything as long as you know the full scale dimensions.
The figures can seem out of scale as GM says. My advice is to not use to many figures and ensure they are surving a purpose on the scene. For a single engined aircraft i would use 4 or 5 max. I am not exactly sure what they would be doing in helping it take off, but if it was a WW2 aircraft, i would probably have 1 removing the chocks and one giving the signal to go.
These are a few of mine from last year. The first is a modern larger sibject, but even here i have only used 3 figures, 2 crew preparing to boardand a ground crewman moving to the starter unit.
On this single engined oine i only used 2, but i think they serve the purpose of explaining whats happening.
Here i have 5 figures, 4 of them underneath.
And these 2, the same type of aircraft, both have 3 figures.
And this one also has 3.
I don’t think any of these over power yet yet they still help explain whats going on.
You can also get kits that are not the scale that it says it is on the box! Not common with newer kits, but some from way back, before my time, were odd scales…they just got relabeled at the closest “mainstream” scale.
I think, even if both, the aircraft and figures, were perfectly in scale…the people are gonna look kinda big. WW1 planes are not large!
And often a kit was sized to fit to a standard box for shipping and display on a store shelf. That’s what people mean when they refer to “box scale”. The classic American model companies all started out sizing their plastic kits that way, but moved rapidly to fixed scales.
Gotta remember at 1/72 scale the difference between someone that’s 6’ and someone that’s 5’ is only .167” so I wouldn’t sweat it too much. I would measure the wingspan of the model and then multiply by 72 and then convert those inches back to feet. If it’s comes up close to 29’ 2” (which is what the full scale Fokker D.VII is) then you can get an idea if your plane is indeed at 1/72 scale. If not then you can adjust everything accordingly.
Everything is 1/72nd (allegedly). Brands do vary, but you can’t be choosey given the shortage of ground crew figures. In those builds i have used figures from 3 or 4 different brands.
If your useing figures from different brands, thats when issues can arise with size. Airfix figures for example are closer to 1/76. Of course real people vary in size, but as mentioned above, in this scale it would be tiny. So placement is important. I won’t put a standing Airfix figure next to a Revell one for example, but a kneeling Airfix figure will be fine.
Just position your figures around the scene and adjust them until it looks right.
