how to make flags.
Hi,
Can anybody tell me how to make a flag? (like those nazi flags placed on top of tanks and trucks)
Thank you,
JESUS JARA
I did one of these a number of years ago by this method. First I used a kleenex sheet and soaked it in a 50 / 50 mix of white glue and water. I then laid it over the location where the flag was going to go and let it dry. I then painted the background of the flag in red with a white center. Finally I placed a decal of a swaztika in the center. This worked pretty good. It was also sprayed with dullcote along with the rest of the model.
Alternatively, use talcum/baby powder to roll very thin sheets of Milliput. Place on the model and gently push into position over any items underneath. Let dry, then paint (the decal svastika is a great idea!).
A guy from forum suggested to me using aluminium foil. It turned out okay, but i painted the swastika badly. A decal will surely help.
If you have spare bucks, you can get http://www.archertransfers.com/AR35008.html
thank you… I only forgot to mention that is a soviet flag, just mentioned the nazi one because it is the most common subject for this (quite bizarre).
Same procedure … change colours … insert red star for swastika. LOL
Jara,
I used a piece of Kleenex sheet, than I airbrushed with red nankim paint. I let it dry and after I painted the the comunist symbol. To fix at the dio base I used a mix of white glue and water. take a look at the result:
Best wishes and good luck! [;)]
Roberto
