How to get the best airbrush experience from acrylic paints (Vallejo, Ammo, Ak, Army Painter, etc)
I created this article many moons ago and a YouTube video (see link). I am hoping this article can help other fellow modelers learn how to airbrush Vallejo Model Air paints.
https://youtu.be/OYyfKPouFCQ
Quick background on me. I started airbrushing at around age 9 and fell in love with it. I am an airbrushing nut (currently have close to 50 airbrushes) and worked as a professional airbrush artist for printing company for many years. I then took my experience airbrushing in the private sector to airbrushing scale models. After working with enamel and lacquers for many years, I have lost my sense of sense. Decided I can’t keep going like this and switched to acrylics. Started with Vallejo and hated them at first. No matter what I did, I could not get them to work right. Main problem was tip drying and that can ruin model. I tried several recommendations from fellow modelers, from Vallejo, etc. Nothing worked at all! After about 15 seconds I would get tip dry. It was just so frustrating. I got rid of them immediately the first time. Due to health concerns, living with pets, and roommates, I decided to give them another try and find a solution.
Vallejo has some good things going for it: very little to no smell, easily available, comes in sets you don’t have to buy individual bottles ( i think they were the first major company to do this), and a fantastic range of colors. So I started to do some tests and found a mixture for airbrushing Vallejo paint and is going to give you great results!
What you need:
-Vallejo thinner
-Vallejo flow improver
-Vallejo retarder
The formula is 90% liquid (Vallejo thinner + Vallejo Flow Improver) and 10% Goo (vallejo retarder)
I use an empty Vallejo 17 ml bottle for this purpose. The liquid portion needs to be: 70% flow improver, 30% thinner. Then add in 10% retarder. Then shake the hell out of the bottle.
For airbrushing, I use either a 50/50 (paint to thinner) or 60/40 (paint to thinner) start with 20 PSI. I prefer to use smaller needle/nozzle setup, .2mm or .3mm. I use the backflushing technique to mix the paint within the cup. Btw, this is a starting point and you adjust as needed for your needs….for example: more thinner and lower air pressure for mottling purposes.
I recommend adding the thinner mixture into your airbrush first! It helps lube the airbrush needle. Also, a little goes a long way. For this example, I added in 5 drops thinner to 6 drops paint. I had so much paint leftover even after the sheet and the test piece.
As you can see from the pictures, I can get fine lines with no tip drying issues. I sprayed on that white sheet for about 5 mins no issues at all. Coverage is great…but YOU MUST USE A PRIMER. Acrylics need primers or they will easily come off. Hopefully the pictures show the wonderful results you can get from Vallejo.
Hope this helps! If you have any questions, let me know.
PS: All models shown are airbrushed with Vallejo Acrylics
I only have one airbrush,and I only paint models for a hobby but I followed Vallejo’s instructions.I use their recommended ratio of 10-2-2
Paint-Vallejo Thinner-Vallejo Flo Improver.
Since adopting this,no tip dry.I also find that I can also use this for Mig and AK acrylics in the 17mm bottles also.
Yes I agree about using a good primer with Vallejo,usually Tamiya or Mr Surfacer.
Thanks
Hi Tojo,
I think you replied to my other post. I accidentally made 3 of the same posts. And I would say that their suggestion is ok but not great. My mixture gives you much much longer airbrushing ability. I can go for 40 minutes to an hour. If you look at my Bf-109 video, that was 40 plus minutes of airbrushing with no issue, consisten spraying, etc. Even in Vallejo’s video, they recommend having a brush with thinner ready to remove build up. Try my mixture and it will completely change your Vallejo airbrushing experience and also it works on any pure water based acrylic.
Thanks,I’m good.[Y]
