How to do molding, casting, sculpting, or scratch building to customize an old metal Hubley kit
I wonder if any of you may know of books or ‘how tos’ for making customized parts to enhance the engine (etc.) on an old Hubley kit. I want to enhance the detail on the vehicle as much as I can, but I’ve only worked with plastic and PE aftermarket in terms of increasing realism in a model. I don’t know the first thing about molding or casting, or taking things further, how to work with scratch building things such as the spokes in the 1932’s wheels. The level of detail on those old kits is in need of improvement to say the least.
I apologize for the expansiveness and generality of this query. It’s been a hard nut for me to crack in terms of learning how to customize with metal or resin on an old metal model kit.
kind regards,
Will
Hi Will!
I’ve never done any work on metal cars either but I think if you go to the “Autos” section of the forums you will find some help. That’s where all the car builders hang out and they are very knowledgeable and ready to help.
Hope that this helps.
Stay safe.
Jim [cptn]
Thanks, Jim! Great idea.
Will
Do you need to cast in metal, or would urethane plastic be okay? There are several youtube videos on making molds and casting urethane in them. Personally I never make a mold with any surfqaces open to air. Those surfaces will not harden properly.
Thanks for the suggestion! I’ll do some searching on YouTube. Urethane would be fine for casting, I think. I still have to figure out whether I will need to do post-cleanup/sculpting on pieces after it’s set up. That’s interesting about not making a mold with any surfaces open to air. I hadn’t thought that far ahead. I have seen open molds in a props molding and casting book (bigger things on a stage), but I didn’t know that a surface open to air will not harden properly.
Depends very much on your materials. As a builder of industrial modeIs back in the days before ‘fancy’ materials and 3-D printing, I used to make silicone molds of parts, then cast them with stuff called “Durham’s Water Putty,” a mix-your-own filler commonly available at hardware stores and home centers. Hardens a treat open to air, easy to work, light weight and inexpensive.
Just another alternative. [:D]
Urethane molding may be suitable depending on your needs. Please note that the open mold surface may not be properly treated.
